Odd Cruise Control Code 122 Issue
Old Jul 29, 2010 | 10:43 PM
Deppdog's Avatar
Deppdog
Stage III
Default Odd Cruise Control Code 122 Issue
I have a 2002 Ultra Classic. The cruise control will not activate. The self diagnostic throws a 122 code, but the brake light switch for the front and rear seem to be working fine, both will activate the brake light. They do not seem to be sticking and the brake light is not stuck on and is functioning properly. The only time I have ever had a 122 code was when a switch went bad and the brake light was stuck on. Could this possibly be an issue with the relay? Any ideas?
Thanks!
Steve D
Old Jul 29, 2010 | 11:59 PM
BDL's Avatar
BDL
I'm glad you posted this, saves me some time. My 03' RKC is doing the exact same thing. I'm suspicious of my front brake switch because my bars were changed out before I bought my bike. Lamps work normally. I opened it up and didn't notice anything obvious. Good luck with yours.
Old Jul 30, 2010 | 02:08 AM
August's Avatar
August
Remember, there's also an inline switch on the throttle (roll off) cable. It resides on the side of the frame at the steering hub (right side). It is a funky design and regularly goes bad (i.e. shorts to ground). I'm guessing that's your problem (if I had a code index, I'd say I'm sure it's your problem).
Old Jul 30, 2010 | 09:52 AM
Deppdog's Avatar
Deppdog
Stage III
It's throwing a code 122 for the brakes, so I'm pretty sure it's not the roll off. I'm wondering if it could be the brake relay? I'm not exactly sure how that relay works. Does anyone know if there is a separate component in the relay for the cruise, or is it all tied directly to the brake switch wiring? The brake light is working fine both off the pedal and the lever.
Old Aug 1, 2010 | 09:19 PM
BDL's Avatar
BDL
Bump.
Can the lite switch(s) be bad and still lite the rear lamp?
Old Aug 4, 2010 | 11:13 PM
BDL's Avatar
BDL
Good job, August! I unplugged my roll off switch and now the cruise works. Weird that it was giving a brake code...
Herbalrides!
Electrical/Lighting/Alarm
Jun 24, 2019 02:30 PM
JCBGlide
2014-2024 Touring Models
Jul 1, 2018 04:21 PM
Kennebec
Sep 8, 2017 11:08 AM
roaddog
Sep 16, 2012 02:35 PM
Joker659
Mar 19, 2012 07:30 PM
