LED Light Bars
Old Jul 30, 2010 | 08:23 AM
al baehr's Avatar
al baehr
Default LED Light Bars
Looking to add a Led bard on my tour pak, I would most likely want to put it underneath so I dont have to drill a hole through the face. Does anyone have any recommendations on where I can find a nice one. Thanks
Old Jul 30, 2010 | 09:59 AM
Buzzsaw's Avatar
Buzzsaw
Friend of mine just ordered this one...not sure how good it is yet since I haven't seen it in person.
http://hoglite.com/
I believe ridetime technologies, has some that stick on the back also...
Old Jul 31, 2010 | 02:00 PM
White Knight 04's Avatar
White Knight 04
I got mine at the 75 chrome shop in Ocala Fla call them I think I payed $35.00 for it about 3 years ago I was there this winter and they still had them 32 lights in it.... Hope this helps they have a web sight....
Old Jul 31, 2010 | 03:16 PM
TheShrink's Avatar
TheShrink
I got mine from Radiantz and it's bright even in the sun. Also wired the ends for signals.
Old Jul 31, 2010 | 08:12 PM
hojones's Avatar
hojones
Custom Dynamics sells a LED bar that is 6"long. I used a piece of Aluminum and made a bracket for it and used 3M double sided tape to mount it under the Tour Pak. Drilled a 1/8 hole for the wires and soldered them into the harness in the Tour Pak. Really shows up when you hit brakes.
Old Jul 31, 2010 | 08:21 PM
ms3300's Avatar
ms3300
My gosh, man, you need to get some lights on the back of that bike!!
Old Jul 31, 2010 | 08:26 PM
ms3300's Avatar
ms3300
J&P carries a LED light bar manufactured by Drag Specialities (P/N 280550). It is a universal fit light that comes with mounting hardware. The hardware however is VERY cheap, I broke on of them taking it out of the package. The lightbar itself is cheaply made as well. However, it was ez to install, I used double sided sticky tape and mounted it underneath my tourpak and ran the wire through one of the factory holes and inside the tourpak where I wired it directly into the harness. It has ridden there for the past 5 mos with no problems.
Old Aug 1, 2010 | 05:56 AM
emwolb's Avatar
emwolb
pay attention while riding around to the third brake light that's at the rear of most suv's. some of them could easily be mounted or adapted to your application. i've been toying with the idea of using two of them in the filler strip between the bags and fender.
Old Aug 1, 2010 | 07:32 AM
Steve Zodiac's Avatar
Steve Zodiac
In the UK you can buy a 24 LED version on eBay for less than $5.00:
http://cgi.ebay.co.uk/NEW-12V-24-LED...item335f7f3e88
They come in different sizes with 14, 24, 36, 48, 60 and 120 LEDs.
Road Star
Dec 26, 2016 06:24 PM
11roadglide
Electrical/Lighting/Alarm
Aug 19, 2016 06:51 AM
beachdive
Feb 10, 2014 06:17 PM
runnhrd
Feb 6, 2011 10:59 AM
marvincbr
Jan 11, 2010 03:47 AM
