Help needed with a Cam choice
As for "running out of steam" at 4500rpm I must respectfully disagree with that notion too. They produce a very flat TQ curve and make power all the way up to the extended redline (6250rpm) with no "hitting the wall" or perceivable drop-off in the process of getting there. They do not produce prodigious amounts of peak-HP and it is not their designed purposed to do so. These cams do not have a "band" where you feel a surge at a give point in the transition toward the redline, which is why may be why some suggest they "hit a wall." That's not the sensation I get when riding my bike, although I'll admit that I live above 4500 rpms only rarely, as the power is more than sufficient below that point, for me anyway. They do produce more peak-HP than stock, but not as much as most other cams on the market. For this reason they would be a poor choice if drag racing is your priority, but for real-world power where you ride I don't think they can be beat for the money spent.
I must disagree. Many have replaced cams on a Stage 1 TC96 with 255's and have been very happy, and I'm a member of that club. They do very well with the stock 9.2:1 compression of the stock TC96 and no other mods, and it is the best bang-for-the-buck upgrade on a stock motor you can do if your quest is increased TQ where most of us ride, IMO, especially if you DIY and buy a low-mileage CVO pull.
As for "running out of steam" at 4500rpm I must disagree with that notion too. They produce a very flat TQ curve and make power all the way up to the extended redline (6250rpm) with no "hitting the wall" or perceivable drop-off in the process of getting there. They do not produce prodigious amounts of peak-HP and it is not their designed purposed to do so. These cams do not have a "band" where you feel a surge at a give point in the transition toward the redline, which is why some suggest that they "hit a wall." They do produce more peak-HP than stock, but not as much as most other cams on the market.
If your "butt dyno" can't feel the natural limitations of the 255 cams, maybe it needs to be recalibrated.
Nobody is wrong here, and it's just a matter of what your preferences are.
By suggesting that another person's butt dyno needs "recalibrating" suggests that you think only your idea of proper cam behavior is the correct one, and/or that everyone else is inexperienced or naive and won't find out 'til he or she rides a real motorcycle. Please, give us a break! I like the way the 255 cams behave in my bike, as well as the cost of the upgrade related to the effect achieved. I was actually quite happy with the performance of the stock TC96 with Stage 1 mods, but I made the cam upgrade only after long and hard deliberation where I considered many different combos. I wanted a bump in TQ in the low-end and midrange without shifting the curve to the right without spending much money, and that's exactly what I got. Mission accomplished, and a bargain for $285 total cost (including a $95 inner-bearing tool).
It's not an attack, you shouldn't take it so personally. All equipment needs calibration from time to time and if the only thing you are using is your "butt dyno" as you've posted so many times, then you might consider a recalibration. That's a lighthearted reference. If you found offense in that, you were reading way too much into it. Next time I'll try and remember to add a
OF course, most aftermarket cam grinds aren't designed for a moderate gain across the entire band. Folks want the most performance they can get, so most aftermarket cams are designed to go in motors with other upgraded componants.
however, in this thread, I think it was during the part where you were telling me what I was thinking, and how I should give you a break, although you didn't exactly say who "us" was. That was what led me to think you might have taken some personal offense... I never suggested you were inexperienced or naive, but that was what you seemed to read into it.....
My original discussion point was on the performance of the cams at the upper rpm range.....
we have certainly been guilty of hijacking a thread in the past as again here.
which seems to me to be a good point for me to bow out, as entertaining as this has been, I think we should spend a little time addressing the OP's questions......
