wiring hellp
Old Aug 3, 2010 | 07:26 PM
sh57's Avatar
sh57
Default wiring hellp
I am installing an ultracool oil cooler and I already have an oil temp gauge which has the sending unit in the oil pan. I was going to wire the fan up to my acc switch so i could turn the oil cooler fan on and off as the need arises. From my searches and looking at the manual one side of the acc switch should be hot. Mine is not. What am I missing?
Old Aug 3, 2010 | 07:33 PM
vickers1's Avatar
vickers1
I had to find mine under the fairing on my '08. It was in a cluster of wires on the left side of the radio (if looking from the front). The wires were orange and probably one or both had stripes. I found them with a test light.
Old Aug 4, 2010 | 09:28 AM
JimTJr's Avatar
JimTJr
On a switch, you don't have a "Hot" side, persay, but if you wire it backwards, it'll be on when it's supposed to be off is all.
Old Aug 4, 2010 | 10:13 AM
sh57's Avatar
sh57
I don't have any juice at all going to the switch, so at this point wiring my fan up to it would have no affect at all.
Old Aug 4, 2010 | 10:18 AM
Arlensmess's Avatar
Arlensmess
5th Gear
You have an acc connector under your seat. It looks like the data link but it's black
Old Aug 4, 2010 | 10:27 AM
vickers1's Avatar
vickers1
That connector is under the fuse box but I couldn't get power there either. If you switch the bike on and flip the switch, it has power if the green light lights up. If it doesn't, check your fuses. It has power from the factory.
Old Aug 4, 2010 | 11:02 AM
sh57's Avatar
sh57
thanks for the help, I have no power at the switch and my fuse is good. I quess I will chase the wire and see if I can find the problem.
robbyville
Sep 9, 2015 06:52 PM
boazbird74fxe
Shovelhead
Aug 7, 2011 12:19 AM
iclick
Aug 16, 2008 06:47 PM
iclick
Jun 12, 2007 07:06 PM
floridian46
May 17, 2007 11:17 PM
