intercom operation ?
Old Aug 14, 2010 | 07:35 PM
tj40kman's Avatar
tj40kman
Default intercom operation ?
As you will probably figure out with this question, I am new to owning a Harley. I just purchased a 07 Ultra. In trying to figure out how to turn on the intercom (still haven't figured it out even using the owners manual), I now have the "set" displayed next to the soft key #6 when I turn on the ignition or ACC. This is when the radio is off.
Thanks, Tim
Old Aug 14, 2010 | 07:41 PM
2WheelGlider's Avatar
2WheelGlider
Turn radio on, press the int button on the left side of the radio. Then the #1 preset key will say on/off next to it. Press the 1 preset key to turn it on, press the 1 preset to turn it back off. Then adjust the vox level with the right side presets, use the volume control on handlebar to adjust drivers volume and use passenger volume lever to adjust for the passenger
Old Aug 14, 2010 | 07:49 PM
tj40kman's Avatar
tj40kman
Does the radio have to be on for the intercom to work?
Thanks, Tim
Old Aug 15, 2010 | 09:08 AM
redultra02's Avatar
redultra02
Thanks, Tim
Yes When you spear on the intercom it will over ride the radio but if you don't want to hear the radio just drop radio volume down to mute.
Old Aug 15, 2010 | 09:42 AM
Harley_RN's Avatar
Harley_RN
Thanks, Tim
The unit has to be turned on but not necessarily the AM/FM selection. Is that what you were asking ? Give it some time and go through all the buttons following the manual. You'll figure it out.
Old Aug 15, 2010 | 07:17 PM
we_brown's Avatar
we_brown
When you adjust volume, the adjustment is made based on what mode you are in. If you have the FM radio displayed and change the volume up or down it will only apply to the FM radio, it will not affect the volume for the intercom, or cb or anything else. If you want to adjust the volume for the intercom you must have the intercom displayed.
Old Aug 15, 2010 | 08:05 PM
tj40kman's Avatar
tj40kman
Thanks for all the help. Shouldn't the "set" icon disappear after I set the clock? Can't seem to get it to go away.
Old Aug 15, 2010 | 08:44 PM
1plumr1's Avatar
1plumr1
on the right hand switch block, push the lower right button and set will go away.
bull34
2014-2024 Touring Models
14
Aug 29, 2017 09:42 AM
Chuck mcg
Jun 5, 2016 09:29 AM
toyman57
Feb 10, 2015 11:55 PM
Bosko
Aug 27, 2012 06:23 PM
Cache
Oct 6, 2006 11:01 AM
