103 upgrade not going as planned
Old Aug 18, 2010 | 04:45 AM
emwolb's Avatar
emwolb
that's exactly where i'm leaning with the newfound ticking. sounds like your timing needs to be ajusted back a few degrees. they'll know when it goes on the dyno. i had a pcv on my streetglide and the canned maps just weren't cutting it for me at all. after the motor build we dynoed it and the tech dialed it in, the cells of rpm's, timing, fuel, etc, and it runs like a pissed off gorilla after he did his magic. if you're getting that spark knock, also known as pre ignition, please don't try to push the motor hard, because that's really hard or damaging to a motor. take it easy on the throttle till it's dialed in properly, then you can go out and rip up the asphalt. the difference with how it runs now and how it will after it's dialed in correctly, will amaze you.
Old Aug 20, 2010 | 07:30 PM
Big Daddy FLHX's Avatar
Big Daddy FLHX
I appreciate all of the responses so far. The dyno is the first week in September. I'll post the both the paper results and the "butt dyno" results.
2mOOn
Sep 15, 2014 06:52 AM
2mOOn
Sep 8, 2014 07:25 PM
crazyanimal
Jun 19, 2012 09:22 PM
EasternSP
Feb 8, 2012 06:43 PM
kwas
Jul 30, 2007 07:48 PM
