6 gallon tank?
Old Aug 17, 2010 | 10:29 PM
Damascus's Avatar
Damascus
I have an 09 RK Police with a 103" motor and time and again, when I get to 50 miles remaining, the bike lets me know it ain't happy.
It may be a 6 gallon tank but the fuel pump likes that last gallon or so all for itself.
Old Sep 9, 2010 | 10:42 PM
Needles65's Avatar
Needles65
6th Gear
Cool The low fuel warning light on my Street Bob
The fuel gauges & low fuel warning lights on Street Bobs & Ultra's may be as different as the bikes. My low fuel light has come on when the gauge was at 2/3 full. My mechanic said one day "fuel gauges are as dependable as SCUD missiles". He also thinks they work better when there's a full moon.
Old Sep 10, 2010 | 04:53 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by wrongway2
When I fill up, if the nozzle isn't to sentitive, I can add a lot of fuel after the initial shut off but it's not always possible with some gas stations.
I think I may have a solution for that filling up problem! I came across a BMW site with a tip to help get that last bit of fuel into the tank, which was to drill holes in the filler neck, to let air out of the top of the tank.
I am in the process of adapting a 2009 6 gallon tank to fit my old Evo and have it in pieces as I write. The photos show the plastic 'top plate' that lives under the filler flap on touring bikes. The left photo shows the top plate viewed from above, in the right it is upside down. The EFI pump, a filter and the fuel gauge device are normally under it, but I don't have them for my carb bike.
So this is my suggestion! Drill say three 3/16" holes into the lower filler neck, underneath the plate, as seen in the right photo, and as close to the plate as practical. That should help fill the top inch of the tank and may improve capacity.
Attached Thumbnails 6 gallon tank?-top-plate-top_e.jpg   6 gallon tank?-top-plate-spout_e.jpg
Old Sep 10, 2010 | 05:27 AM
cdestuck's Avatar
cdestuck
Like other said, it is 6 gallon. Trust me I know...but a bit lucky when I found out. Knew I had to be on fumes and did get to a station. Put in 6.01 gallons.
Old Sep 10, 2010 | 06:37 AM
bdp's Avatar
bdp
Originally Posted by HOG_0308
I was having the same issues... now I know it isn't a good idea to run an EFI bike dry, but I had to know. No one could give me an answer. So I had a Qt gallon gas can. I put that in the tour Pak. I filled up the 6 gallons and headed out for a freeway ride which took me from San Diego to Yuma. I got 244.8 miles before I got a sputter. I pulled over right away and then put the qt gallon I had in the can and then found a gas station about three miles down the road. I filled up and then headed home. Silly experiment maybe, but my gauge was on empty at 194, the reserve with 54 miles came on and the low fuel light was also on until I hit the 244.8 mark. I was cruising 80 to 85mph cruise control the entre way.
I go by the miles, not the gauge. The gauge gives me an idea, but the miles are what I go by if I'm riding long distances.
So, how much gas did it take to fill up?
Old Sep 10, 2010 | 07:20 AM
shortride's Avatar
shortride
I've gotten as high as 242 miles before having to fill up. It took 5.4 gallons to top-off the 6 gallon tank. What I was surprised about was, after removing the almost 40 pound tour pak, the fuel mileage got a little better.
Old Sep 10, 2010 | 07:23 AM
audettd's Avatar
audettd
Totally agree....I've yet to put in more the 5 gallons and I've been down to single digits on the clock. I'm not complaining mind you....but I've found I usually get around 225 before I have to fill up...I know for sure I can get another gallons worth of mileage..but why push it.
Old Sep 10, 2010 | 07:45 AM
02ULTRA's Avatar
02ULTRA
The problem is the fuel gauges are not accurate at all. I have calibrated mine and two others to where it shows completely empty there is approximately .5 of a gallon left.
The gauge and the "Low Fuel" light are driven by the float in the tank, it is all part of the fuel pump, filter and regulator assembly. The float is on a wire arm that is about the same gauge as a wire coat hanger. If you follow the steps to replace your fuel filter, the entire assembly comes out of the tank. While holding the wire as close to the pivot point, you need to gently (very gently) bend the wire arm up a little at a time making sure to hold it tight at the pivot point. I found it most accurate if you completely drain the tank, measure exactly 3 gallons if you have a 6 gal tank or 2.5 gal if you have a 5 gal tank, put measured gas in tank and replace the pump/filter/float assembly with 2 or 3 screws, turn on ignition and check gauge, if not exactly at 1/2 tank (be sure bike is level and not on side stand), repeat previous steps until gauge is calibrated to 1/2 tank. When you are satisfied reassemble. That is as close to accurate as you can get with the gauges.
I recommend for the next few tanks of gas that you confirm accuracy with your trip meter.
Old Sep 10, 2010 | 09:13 AM
grbrown's Avatar
grbrown
Thumbs up
Originally Posted by grbrown
So this is my suggestion! Drill say three 3/16" holes into the lower filler neck, underneath the plate.
Practicing what I preach, I have just drilled those three holes, using an 1/8" pilot first and a 6mm I had close at hand. The plastic is very easy to drill with a hand drill (not electric). It may be a while before I actually get my tank on my Evo to see if it works.
That's a great tip from 02Ultra for calibrating the fuel gauge. On recent bikes the float is part of the top plate assembly.
Old Sep 10, 2010 | 11:52 AM
scoteh's Avatar
scoteh
The most gas I have put in my '08 has been 5.4 gallons. The countdown was at 2 miles left. My pal, with a 5 gallon tank but who gets better mpg than me, had just sputtered to a halt. I usually just fill up by 150 miles, as I probably need a break anyway. Besides, HDs are not fun to push!
Capt Steve
Mar 16, 2018 10:15 AM
kryingame
Oct 26, 2014 12:16 PM
PopsHD
2014-2024 Touring Models
Aug 28, 2014 06:08 PM
UnoLocoMoFo
Apr 15, 2011 10:01 AM
beary
Jul 24, 2009 09:31 PM
