Should I install CB Setup myself or dealer?
Old Sep 3, 2010 | 07:57 AM
MyClassic09's Avatar
MyClassic09
Started to follow directions to figure out the holes for the cb antenna...
but if I followed directions it will be almost a inch off from where the radio antenna is and would look stupid...
mainly Eyeballing it and will have it so close to the same you wont be able to tell...
have to run that cable then start zip tying everything up and start putting back together.
Old Sep 8, 2010 | 07:33 AM
MyClassic09
got it all installed and I did not need to do the flash to use the intercom.
Well the passenger setup for the 77108-09 is in the way of the saddlebag to close and its hard for the wife to reach...and how I install the rider on the tank was very cheesy and the part keeps the console from mounting down on the tank properly. I would not recommend this product to anyone...in hindsight I would get the center console insert and the rear speakers even though that cost more that way...
Old Sep 8, 2010 | 08:37 AM
Harleypingman's Avatar
Harleypingman
When you can, take some pictures of the rider headset connector (showing the console problem) and the passenger control stalk and saddlebag.
Carl
Old Sep 8, 2010 | 09:19 AM
MyClassic09
The camera I have is good for photos but just cant do close pics always blurry no matter what setting...for the console...
its the metal tab they give you in the package that has a v groove to fit under the lip of the console and go over top of rider plug. So it makes console on that side raise up a little.
as far as passenger it sits right above the air shock inlet stem..so when I go to close the saddlebag I have to push the whole setup over with the saddlebag to get it to close properly...I might see if I can come up with custom bracket to raise it up just a little to clear the bag..the ol lady will just have to reach...lol
ext1bab
2014-2024 Touring Models
11
Jan 15, 2018 03:46 PM
craigcrewcheif
Jul 27, 2013 04:18 PM
Rocinante
Audio Systems
19
May 16, 2013 07:29 AM
SGChick
Nov 15, 2007 06:26 AM
emt364
Jul 24, 2006 11:43 PM
