Knocking noise?
Old Aug 23, 2010 | 09:01 PM
Lawdawg's Avatar
Lawdawg
Default Knocking noise?
Sometimes when i am riding two up and starting out in first gear there is a knocking noise, I have to feather the clutch some. Is it the load on the engine from the extra weight or the clutch slipping? It sounds like the bike is starting out in 2nd gear. Thanks for the help.
Old Aug 23, 2010 | 09:10 PM
18BKLR's Avatar
18BKLR
SE Comp Installed?
Old Aug 23, 2010 | 09:24 PM
Lawdawg's Avatar
Lawdawg
NO... I was wondering if that might help. I am having problem with starting and kick back.
Old Aug 23, 2010 | 09:31 PM
18BKLR's Avatar
18BKLR
I am not having any starter issues but I do get that shutter at take off a little. I have one on the way for mine right now. Comp and the HB wedge while I am in there. It was just a thought I had for you. Maybe those IDS rubbers as well. 2 up puts a little more weight on the back and it might be that comp that you are hearing that can't take it. Let us know what you find out.
Old Aug 23, 2010 | 10:12 PM
Lawdawg's Avatar
Lawdawg
Thanks, just thought it was my fat *** causing it, guess i can tell the wife to get off my case.
Old Aug 23, 2010 | 10:32 PM
bwana1's Avatar
bwana1
Compensator. If still under warranty have it replaced with the S.E. compensator and just pay the difference. Labor should be covered with the warranty.
Bwana
Old Aug 24, 2010 | 07:01 AM
smokindave's Avatar
smokindave
Last time I will type this (maybe). THE STOCK COMPENSATOR IS JUNK!!!!
Old Aug 24, 2010 | 07:19 AM
todd-67's Avatar
todd-67
I agree with the others. Sounds like a compensator issue to me unless you are trying to take off at too low RPM.
Old Aug 24, 2010 | 07:35 AM
cezariomaia's Avatar
cezariomaia
It's not the compensator. Mine did the same noise and I found I was starting to ride at a very low RPM. Just a litle bit more of throttle and you "take off" without any noise.
C908
Apr 5, 2022 01:10 PM
goose222
Jul 8, 2014 07:09 PM
yuandp
14
Jul 3, 2014 05:44 AM
P51Driver
Oct 17, 2012 02:14 PM
docksman4
Jun 29, 2007 09:39 PM
