Speaker Brackets Broken
Old Aug 24, 2010 | 09:05 PM
PVSG's Avatar
PVSG
Default Speaker Brackets Broken
Yesterday I removed my fairing for the first time ('08 SG) and while I was in there I noticed that both of the thin silver brackets that connect to the speaker were broken. Today I read many other threads that mention this problem, so I guess it's pretty common. I've never actually noticed any fairing vibration or anything like that, so I'm wondering if this is something that I need to address urgently or can it wait until the next time I remove the fairing?
Old Aug 24, 2010 | 09:08 PM
dawg's Avatar
dawg
They've since been upgraded. I'd replace them now with the newer ones.
Old Aug 24, 2010 | 09:13 PM
Streetrunner's Avatar
Streetrunner
Do not wait. You are adding stress to the two larger, vertical brackets. They break under normal condition. no need to accelerate the problem.
I have been through both horizontal and vertical more than once on my SG. It's a very common problem that bat wings are prone to.
Old Aug 24, 2010 | 09:51 PM
krazy3's Avatar
krazy3
Welcome to the club!!
Old Aug 25, 2010 | 08:28 PM
PVSG's Avatar
PVSG
Thanks. I'll pick up the new brackets tomorrow and get them installed pronto.......
Old Aug 25, 2010 | 08:32 PM
SMSgt B's Avatar
SMSgt B
If your warranty is still valid, you might get them replaced for free....at least I did (had all 4 replaced)
Old Aug 26, 2010 | 10:26 AM
PVSG's Avatar
PVSG
Just checked with the dealer. Because I bought the bike in August '07, he can't cover it under warranty. Also, when I opened the fairing up this morning to replace the speaker brackets I looked at the vertical brackets and found that they are cracked also. So now I'm going to have to replace them too. So I'm sort of back t0 my original question - Since I'm not noticing any fairing vibration, is this something that has to be done urgently or can I wait until riding season is done?? Thanks for the help everyone.
Old Aug 26, 2010 | 10:35 AM
simpkinst's Avatar
simpkinst
yes. and aslo should be warrenty fix.
My '06 broke all 4. replace speaker brackets with new designed ones and fixed the 2 uppers myself.
Old Aug 26, 2010 | 11:51 AM
iclick's Avatar
iclick
Replace them with the new type and also consider fortifying the verticals at the top while you're in there. Here's a write-up on this procedure. Just fortify the bracket like I did the left side in the write-up and they should last indefinitely. Otherwise I think you'll find these will break too in time. The vertical brackets have also been upgraded, I think.
Old Aug 26, 2010 | 12:24 PM
silverbullitt's Avatar
silverbullitt
When were they upgraded? I have an 09 and am going to have the fairing off in a few days.
