front brakes pulsating
Old Aug 26, 2010 | 06:24 AM
cannedham1's Avatar
cannedham1
Default front brakes pulsating
A friend brought his 05 RK over because his front brakes are pulsating when the brake is applied. I rode it and it is pretty noticeable. I used a dial caliper on the rotors and spun the wheel to see if the rotors were warped but they dont seem to be. Any one have any thoughts on this or experienced the same thing.
Old Aug 26, 2010 | 06:27 AM
Notgrownup's Avatar
Notgrownup
Bleed the system...new fluid wouldn't hurt. If there is air in the system it may pulsate a bit...
Old Aug 26, 2010 | 06:54 AM
dawg's Avatar
dawg
Also clean the pistons
Old Aug 26, 2010 | 06:58 AM
smokindave's Avatar
smokindave
Take the calipers apart and clean the pistons. Get a new gasket / o-ring kit from the dealer and make sure you use silicone grease on the pistons when you put it back together. The pistons are probably sticking in the bores. If the pistons are found with any pitting on them, replace them. You may find the pads have worn uneven. This is also an indication of sticky pistons. I did my buddies 03' RK and put on new pads while we were at it, pulsing went away.
Old Aug 26, 2010 | 08:25 AM
relli's Avatar
relli
i dont know of anything that will cause a pulsation other than a warped rotor or drum
Old Aug 26, 2010 | 09:51 AM
xxxflhrci's Avatar
xxxflhrci
I agree...
Old Aug 26, 2010 | 10:47 AM
Cheiron's Avatar
Cheiron
The rotor can have good run out and still give a pulsation if it has surface hard spots.
Hard spots are caused by excessive heat applied, such as heavy loaded and a panick stop. In an automotive application the rotors would be skim cut to remove the surface hard spot and new pads installed.
Old Aug 26, 2010 | 11:28 AM
The Northern Bum's Avatar
The Northern Bum
Out gassing from the brake pads will cause brake pulsations, look it up on the WEB. If the pad is out gassing too much it will cause a slip (too much brake pad gas) and grab (when the gas escapes) between the pads and rotors.
I chased this down on a Chevy Tahoe once. Went through everything on the brake system to find out at the end it was the relatively new brake pads I had installed earlier. They were out gassing too much. Replaced the pads and all was good again. I will admit I never thought it would have been the pads but after researching the WEB I discovered this is not all that rare of an issue. Most just don't try to fix it or give up trying.
My brother in-law had the same issue with his 2000 Road King. Took him a long time and a lot of money (rotors, calipers, new brake fluid) before he believed me and replaced the front pads. Guess what, after replacing the front pads it stopped smooth as silk again.
Good luck, it might not be this, but it could be.
Dave
Old Aug 26, 2010 | 02:47 PM
huffhuff's Avatar
huffhuff
Dave
seriously? grew up in a harley shop and many auto shops and never heard of pad gassing. please enlighten!
Old Aug 26, 2010 | 03:03 PM
glkshooter's Avatar
glkshooter
What Dawg and Smokindave said. Just had my 06 Ultra checked and that was the problem.
