Engine changes in 2011?
Old Aug 27, 2010 | 07:32 PM
stro1965's Avatar
stro1965
Originally Posted by jrudicel
I was reading about some changes in the engines for 2011... Whats everyones take?
Bushing-less cam plate
•Bushing-less rods (running change)
•New induction module / throttle body
•Retainers added for right main bearing
•New breather assembly in the head (running change)
•New bearing in clutch hub
•New compensator for all Touring models
Looks like they will now hone the rod ends instead of machining the hole.. To me thats better tolerances?
No bushing in cam plate?? hmmm...
Just curoius as to what this really means.. Better cost for HD or better quality for us or ???
Where did you find the info on the new clutch hub bearing? I've searched and searched the HD site and can't find anything.
Old Aug 27, 2010 | 10:00 PM
groupw's Avatar
groupw
Originally Posted by toothdocthc
hd has made alot of nice changes that i for one think are very desireable.
.... i'm w/you Doc, now all the MoCo's gotta do is turn out an RGU in the right color & i'm there !
Old Aug 28, 2010 | 07:42 AM
JollyRogers's Avatar
JollyRogers
Originally Posted by bikes
I hope they fix the starter kick-back problem.
Not sure if we are talking about the same thing, but MY '11 RGU does not have the start bang I would always hear. I presumed it's because of the SE compensator... I was so used to the loud bang at start, when I first got the '11 it took me a couple days to get used to starting it.
Old Aug 28, 2010 | 10:40 AM
jrudicel's Avatar
jrudicel
I found a link in this thread... Well worth checking out..
https://www.hdforums.com/forum/touri...cal-forum.html
Old Aug 28, 2010 | 10:54 AM
stro1965's Avatar
stro1965
Thanks, I found it. It says the new clutch hub bearing "retro-fits back as an assembly", which apparently means replacing the entire clutch hub. What it doesn't say is WHY they made the change.
g1bonnette@aol.com
Nov 8, 2016 07:44 PM
Twrguy
Sep 21, 2011 08:32 PM
hydrolock43
Nov 3, 2010 08:38 PM
Mi3ninos
Exhaust System Topics
Aug 29, 2010 11:20 AM
hydrolock43
Jul 31, 2010 02:54 PM
