shifter linkage
Old Aug 27, 2010 | 01:49 PM
John7253's Avatar
John7253
Default shifter linkage
04 ultra my shifter linkage comes apart happen twice put it together first time tighten it all down 800 miles later running down the thruway can't shift. It seems all i can do is put back together tighten it all down and hope for the best unless someone out here can let me know if this is a common problem and if there is fix for it
Old Aug 27, 2010 | 01:54 PM
HDJIM1158's Avatar
HDJIM1158
same thing happen on my 09. Upgrade the rod, make sure the upgrade has good ends.
Be safe JIM
Old Aug 27, 2010 | 02:06 PM
petemac's Avatar
petemac
Happened on my bike around 15k miles. Replaced it with one with heim joints.
Old Aug 27, 2010 | 02:14 PM
DooZ's Avatar
DooZ
Are you using loctite/threadlocker when you reassemble?
Old Aug 27, 2010 | 02:19 PM
rh8234's Avatar
rh8234
Loctite is a harley owners friend! Use it.
Old Aug 27, 2010 | 02:59 PM
FastHoss's Avatar
FastHoss
I have never had a problem.Heim joints,double nuted with loctite.
Old Aug 27, 2010 | 03:06 PM
gmc's Avatar
gmc
http://cgi.ebay.com/ebaymotors/ECON-...Q5fAccessories
Heim joints if you don't want to pay $$ .
Old Aug 27, 2010 | 09:12 PM
TMair's Avatar
TMair
From what I understand there is also a replacement rod that is larger then the factory, mine has the larger rod, and I have nad no problems with it, neither has the previous owner, but I don't know if it is less expencive then the heim jointed ones, if I where going to replace mine I would look at the heim jointed ones, they look pretty fool proof to me.
Terry
Old Aug 29, 2010 | 12:23 PM
John7253's Avatar
John7253
Thanks for the info. Going to try the loctite first
Old Aug 29, 2010 | 01:51 PM
KutenFLHX's Avatar
KutenFLHX
I loctite any bolt that I loosen. Cheap insurance to make sure the bolts don't come loose.
