Dynojet Sensor WBC O2 sensor location?
Old Aug 27, 2010 | 03:56 PM
flyer91's Avatar
flyer91
Default Dynojet Sensor WBC O2 sensor location?
I have Fullsac TD's and am adding a DJ Wide Band Commander.
As I understand it .... the O2 sensor needs to be within 30" of the rear header flange (?).
Any suggestions as to where to mount it's bung so it doesn't stick out like a sore thumb?
Pictures of your install would be great.
Old Aug 28, 2010 | 04:48 AM
Watch Guy's Avatar
Watch Guy
Default Hmm? not exactly sure about your system
but the O2 sensors for the exhaust are withing about 12 inches of the header joint on the 09 FL's and right next to the right side footboard on the 10's and 11's
The PCV doesn't even use the O2 sensors so are you sure your does?
Old Aug 28, 2010 | 11:42 AM
flyer91's Avatar
flyer91
No my doesn't, but I'm adding a Dynojet wide band commander so I can tweak my PCIII maps using the air fuel ratios at different throttle positions, that the WBC provides via the LCD-100 data logging capability, while riding.
To do this you need to mount the WBC's Bosh O2 sensor (the same sensor the WBC2 uses with the PCV and LCD-200 to add auto-tune to the later bikes) in the exhaust.
What I'm hoping somebody can provide for me is the 'total' length of the Bosh sensor, from the exhaust to where the cable attaches (including the bung).
Old Aug 28, 2010 | 12:21 PM
Mike's Avatar
Mike
I had a Fullsac with the O2 sensor bung, which was mounted on the inside of the "U". Rather than installing a sensor bung in the fullsac you have, you might consider selling it and buying one with the bung already in place. It might save a bit of hassle and look better, too.
I'm not at all familiar with the Wideband II. I have the autotune on my bike, but I had to go to PCV to use it.
Old Aug 28, 2010 | 12:47 PM
Mike's Avatar
Mike
I couldn't find any pics of my fullsac installation, but in this pic, you can see the rear O2 sensor on my Rinehart exhaust. The sensor kind of angles down with the Rineharts, and I think the fullsac was similar. On the stock headers, the O2 sensor was more horizontal.
Old Aug 28, 2010 | 04:21 PM
flyer91's Avatar
flyer91
I am under the impression that the sensor should not be mounted beyond more than 10ş down from horizontal, to prevent moisture from causing an incorrect reading.
Maybe this is only a concern at start-up, and becomes a moot point as the bike comes up to temp. (??)
I'm hoping I can mount it in the header pipe so it parallels the starter, just after the second curve (from the flange) between the two heat shield clamps for the first and second rear cylinder's shields.
As best I can determine, the sensor is about ~2.5" long and 'should' fit in there .... if I can find a welder that can place the bung in my exhaust so it will be between the two heat shield clamps, and at the right angle for the sensor.
HardyHarHarley
May 18, 2023 04:14 PM
cajun1957a
Mar 22, 2016 05:31 PM
hdkev
Aug 12, 2014 12:41 AM
shrini23
Oct 7, 2009 10:34 PM
JekyllnHyde
Aug 11, 2009 05:34 PM
