tuner/pipes/air cleaner ???
Old Sep 8, 2006 | 05:33 AM
hotpursuit's Avatar
hotpursuit
Default tuner/pipes/air cleaner ???
so many options....
im thinking... pc111, big sucker 2, and a good 2 into one.....
but i really like duals..... has anyone test there scoots with both exhausts on a dyno.... would love to see numbers.... keep being told 2 into one is the way, but i like the true duals
Old Sep 8, 2006 | 06:44 AM
xxxflhrci's Avatar
xxxflhrci
Default RE: tuner/pipes/air cleaner ???
Yes, most of the time a good tuned 2 into 1 will out perform a set of duals, especially in the bottom end of the chart. However, I wouldn't let that stop me from getting duals. I put V&H Duals on my bike using the same mufflers that I had ran over 52k. I could tell a definite difference in the bottom end. I made some lollipop baffles (see below) for some added back pressure and gained back some of the loss. Like I said before, I ran the stock head pipe for 52k. It ran great with the Stage I burn. After adding duals, I had to put on a DFO to add a bit more fuel. It runs pretty stout now.
Lollipop baffle - Take a 1/4 bolt and cut the head off. Weld a 1 inch washer on the top of the bolt. Weld the washer hole shut. Drill a hole in the head pipe just in front of the muffler and put the lollipop in there. You can turn it to vary back pressure for tuning.
Old Sep 8, 2006 | 08:04 AM
Bryan TTM's Avatar
Bryan TTM
i run true duals...lost alittle maybe...so i just built some silly power #'s...and run the duals...i never notice any loss cause i make lots...and the sound is staccato and deep [8D]
Old Sep 8, 2006 | 10:32 AM
bountyhunter's Avatar
bountyhunter
You are on the right track...CLAMPFREE DUALS are the way to go! Great sound, power and appearance!
Old Sep 8, 2006 | 11:40 AM
Garemlin's Avatar
Garemlin
Big Sucker Stage II is overkill unless you are doing or planning a bigger build. Engine only sucks as much air as it needs and the Stage I or Screamin Eagle with K&N gives it what it needs. I ordered all of the individule parts of the SE (with chrome backplate) and the K&N filter and it cost me less than a BS Stage I or SE with the silver backplate.
Old Sep 8, 2006 | 01:04 PM
hotpursuit's Avatar
hotpursuit
thanks for the info guys..... the ness air filter is in the mix due to a 95 inch kit being done down the road.... probably next winter..
Old Sep 8, 2006 | 07:02 PM
rollover's Avatar
rollover
All of your add ons sound familiar.
Old Sep 8, 2006 | 10:25 PM
asuperheat's Avatar
asuperheat
Alwayse thought I would loose tq down low w/duals but it can be tuned out wouldent of believed it my self if they dident prove it on my bike and I dont think eny thing could be gained for me with a 2 into 1. Go true dual you will be happy and yes they are louder! I incresed tq all the way across the rpm range switching from stock head pipes to tru dual head pipes with the same slip-ons.
Old Sep 9, 2006 | 12:44 AM
xxxflhrci's Avatar
xxxflhrci
ORIGINAL: asuperheat
Don't discount the gains from the 2 into 1. Dhutchison, a member here, has a 88' with nothing that had nothing but 203s, a PCIII with a homemade map and a Pro-pipe on it. He had it dynoed last month to get a base line before swapping to gear drive cams. He got 84/94 out of it. Imagine what it might have put out if he had a 95' and heads with work on them like you have.
slow black ss
2014-2024 Touring Models
Oct 28, 2014 01:13 PM
blusmbl
Dec 9, 2011 09:29 PM
Fire-Medic
Mar 9, 2011 07:53 PM
lars.eelman
Feb 15, 2011 01:14 AM
scottma978
Feb 1, 2010 11:08 PM
