Ring Gapping?
Old Sep 3, 2010 | 11:44 AM
nemick's Avatar
nemick
Default Ring Gapping?
Does anyone know if Big Bore kits come with the rings already gapped or is that done at the time of assembly?
Old Sep 3, 2010 | 11:50 AM
cuda67bnl's Avatar
cuda67bnl
Depends on who you buy the stuff from. Places like Hillside will fit the rings to the cylinders. If that's the case, the rings will be on the pistons, and they will be marked. The corresponding cylinder will have the same mark. If you buy a kit and the rings aren't already on the pistons, but are still in the box, you'll need to gap them yourself.
Old Sep 3, 2010 | 12:31 PM
Glenn W's Avatar
Glenn W
As Cuda said, and as an unsolicited general rule, "Never install new rings without checking the gap." period. It just isn't worth it. I .001" difference in bore is .003" difference in ring gap so it's real easy to get in trouble. For the price of a set of feeler guages and a little time, you'll sleep better and avoid some scored cylinders if the gap is non-existant in actual use.
Old Sep 3, 2010 | 12:42 PM
PhilCat th PeaceFrog's Avatar
After hundreds of bb installations I never seen rings from a HD kit needing any further attention but we check them every single time just 4 conformation. After market I've no experience but a couple of Dave Mackey kits & they were set correctly out of the box as well. I'd check everything anyway just so you know its correct have fun & #ridesafe
Old Sep 3, 2010 | 03:12 PM
harry.b's Avatar
harry.b
Mine were CP pistons, and yes the rings needed gapping. I bought one of those rotary gapping tools for around $40.00 and it did the trick no problem.
Meatpants
Shovelhead
Mar 27, 2017 07:28 PM
fltrxcrzy
Jul 31, 2016 07:48 PM
nomad billy
Engine Mechanical Topics
34
Feb 20, 2015 08:14 PM
128auto
May 30, 2013 10:51 AM
Varooom
Apr 11, 2010 04:29 PM
