Black denim repaint
Old Sep 3, 2010 | 05:35 PM
bmcgc's Avatar
bmcgc
Default Black denim repaint
My new to me black denim 09 EGS has a scratch on the rear fender, I also want to add a SG rear filler panel.
I stopped by the painter that I want to use and he tells me that he can get the black denim but doesnt know how to match the clearcoat.
I can probley take out a second on the house and get the clearcoat from HD, but Im hoping someone has figured out a way to replicate it.
Anyone?
Old Sep 3, 2010 | 06:10 PM
Lancemchn's Avatar
Lancemchn
Ask him to do a few "sprayouts" using different amounts of matte paste marking each one with the amount and compare the samples to your original. My buddy had the same problem and that's what our painter had to do, AFTER spraying the wrong sheen first. DOH!!! Good luck!
Old Sep 3, 2010 | 06:15 PM
troop's Avatar
troop
According to www.colorrite.com I don't think you use a base/clearcoat...
http://www.colorrite.com/matrix-colo...TOKEN=26408867
Old Sep 3, 2010 | 07:11 PM
timbo141's Avatar
timbo141
Paint systems will have the clear coat recommendations with the formula in the "notes" section.
In this case they all have a pre-mixed flat clear available in quarts. But have a hardener and reducer that is mixed with it.
Side note: Flat clears cannot be buffed as they increase gloss as you sand or buff away the flattners. (Flattners migrate to the surface as it flashes)
Another side note: I think it would be kinda cool to clear with a soft touch clear. It is a flat clear that feels like velvet.
Old Sep 3, 2010 | 10:00 PM
bmcgc's Avatar
bmcgc
The PO tried to "buff" the scratch out. All he did was make a scratch with a big shiny spot around it.
Old Sep 3, 2010 | 11:34 PM
roadgliderick's Avatar
roadgliderick
u can buy factory pack satin clear it usally takes two coats and your done.
Old Sep 4, 2010 | 01:38 AM
Harleypingman's Avatar
Harleypingman
Anyone?
Just stop by the parts counter at your local dealership and order the SG filler panel in black denim if the SG was offered in that color--list price will be about $100; use the parts book to see what other parts you will need, e.g. tri-bar LED light, etc.
Carl
screamin nightster
Aug 31, 2015 10:41 PM
Halfbuck
Powdercoat & Paint
Mar 5, 2014 08:27 PM
lateralus
Jul 18, 2013 12:36 AM
MikeK02048
Jan 9, 2013 04:21 PM
sh4325
Powdercoat & Paint
Jul 24, 2011 11:01 PM
