110" or 103"?
Old Sep 4, 2010 | 06:37 PM
twodollarbill's Avatar
twodollarbill
Most of us have been riding Harleys for a while.
Remember the evo days....and then the twin cam came along with all that power in 88 ci......WOW!!!!
I'm plenty happy with 96 ci.
Will I buy a 103 ci......YOU BET YOUR *** I WILL.
Will I buy a 110 ci......someday.
Old Sep 4, 2010 | 06:52 PM
2WheelGlider's Avatar
2WheelGlider
Have to agree with other posters on the 110. If you are going to go through the expense of splitting the cases, you need to just go all out with something really mean and nasty.
Other than that, do the 103 with good tuner and right cams. Very nice power for the real world riding, at least, IMO.
Old Sep 4, 2010 | 06:55 PM
jeff.georgalas's Avatar
jeff.georgalas
Originally Posted by thecort
I have to say thanks to you guys for your help/advice because I was really considering doing an SE 103" kit, but after reading all the suggested material I'm probably not going that route now.
Looks like I'm going to wait & see how this 107" kit turns out with the TW-555 because if it performs as good as it looks it'll be just what I'm looking for.
And just in case you do decide to go the 103 route, spend the extra bucks to have the heads street ported and bump the compression, otherwise you're pretty much wasting your time. The difference between the stock 103" Harley sells you and the 96" are very minimal in my opinion.
Old Sep 4, 2010 | 07:01 PM
mitchflhx's Avatar
mitchflhx
Default 110 or 103
Unless I am missing something, if this is a 2010 you should not have to split the cases to do a 110. The stroke for the CVO 110 is 4.38, the same as a 96. The difference is the bore 4.00 vs 3.75.
Old Sep 4, 2010 | 07:06 PM
mitchflhx's Avatar
mitchflhx
Default 110 vs 103
Unless the spigots, on the 4.00 bore are bigger than the stock jugs, in that case you would have to bore the cases......$$$$.
Old Sep 4, 2010 | 07:11 PM
mitchflhx's Avatar
mitchflhx
Yes, i checked the SE parts catalog. The 110 kit requires case boring. Sorry.
Old Sep 4, 2010 | 08:12 PM
thecort's Avatar
thecort
Don't want to split cases...yet! What's the stock compression?
Old Sep 4, 2010 | 08:24 PM
Guntoter's Avatar
Guntoter
Remember, when you start bumping that compression up too high, pump fuel, even the premium grades, just is not going to cut it. Sure, the spark sensor will probably knock the timing back to stop the spark knock but that defeats the purpose. Or you could use a cam that lowers cylinder pressure at lower rpm's (lot of overlap?) but then your torque goes out the window. In some places out on the road you may only be able to find 89 octane 10% ethanol "premium" gas. Pure crap gas in my opinion.
I would be hesitant to go over 10 to 1 compression on an engine you plan on street riding or touring with.
Old Sep 4, 2010 | 09:05 PM
thecort's Avatar
thecort
I'm planning on staying on the street & touring with it. But, I do ride the Glide hard enough to drag the floor boards though (stock suspension & no extra weight...besides my gut!). I always like to get a little educated about a product that i'm installing/having installed in my bike. I won't put something in there just because someone says it's good. I want to know why it'll be good for me & my style of riding.
That thread on Fuel Moto's cam comparo & 107" kit has been super informative/helpful. I like
Old Sep 4, 2010 | 10:26 PM
rdoucet's Avatar
rdoucet
I would go with the 103" kit. I just purchased a 2010 FLHTCU last Saturday because I wanted something more comfortable for the wife and I to go out on besides my night train (plus they took close to 5k off the sticker price so they could make room for the 2011's).
I have a stage IV kit on my 2007 night train and that bike is fast enough for me. For the 2010, talking to dealer now - said the 103" kit would be $1500 installed. Since I am having the stage I kit done (pipes and air cleaner), I would save roughly $300 dollars on dyno tuning by doing all at once.
I have until the bike goes in on Tuesday to decice if I want to do the 103" kit. Being a full dressed bagger, bike runs hot to begin with. I am going to install oil cooler and change to synthetic oil at 1K service. Dont know if I will even touch the motor since I have the night train already.
As for your question, I talked to the mechanic who did the work on my night train and he told me to stick with the 96" motor, change the pipes and air cleaner and just ride the thing. Sure the 103" would have more torque and power, however, it would have more heat as well. He told me if I was dead set on doing work to the engine, then go with the stage II 103" kit with S.E. cams. He told me if I start going larger displacement, due to size and weight of bike - and fact that I will be doing two up riding - I am just asking for issues down the road.
Hope this helps.
