I need troubleshooting code information
Old Sep 5, 2010 | 12:07 PM
shortride's Avatar
shortride
Default I need troubleshooting code information
I found a post with troubleshooting codes for up to 2008 bikes but I'm not sure they apply to '09 touring bikes.
I had a problem this morning when I was getting ready to take off on a ride.
Ignition on, the check engine light came on and went out like it normally does. The bike wouldn't start the first time. I turn the ignition off for a few seconds and then back on, waited for the check engine light to go off and it fired right up. I went for a short ride and about 5 miles down the road the check engine light came on for about 20 seconds and then went off but the engine continued to run ok.
Any help will be appreciated.
Old Sep 5, 2010 | 03:31 PM
petemac's Avatar
petemac
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9. Press and release the odometer reset button to continue to the next module.
10. Turn Ignition switch to OFF.
Below are some of the DTC fault codes, but you will probably have a code from your cruise control which isn't listed below
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed gh EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage LoOpen/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector Hiw
Old Sep 5, 2010 | 03:52 PM
shortride's Avatar
shortride
I got, PO118 Engine Temperature Sensor Voltage Open/High EFI. I cleared the code, started the engine, shut it off and re-checked it and didn't get any code. Does anyone know what caused this or what I should do next short of taking to the dealer, AGAIN?
Old Sep 5, 2010 | 03:57 PM
petemac's Avatar
petemac
Look up the code on the list and go from there. A lot of the times if you put the code # into the search function you'll see a detailed description of what the problem was and what they did to fix it. What's the code(s)?
Old Sep 5, 2010 | 04:00 PM
shortride's Avatar
shortride
I read all of the posts with a PO118 search and not one post explained what caused the code. I know what the symptom was and I know what the code is and what it says the problem is but I was wondering if anyone knows specifically what causes that failure. After I cleared the code and went for a ride, the bike ran fine. I got home and did a diagnoses check again and there was no code.
If there is an engine temperature sensor failure, it's not going to fix itself is it? Why did the PO118 code not re-appear after it was cleared? That's what I'm trying to learn about.
Old Sep 5, 2010 | 04:02 PM
petemac's Avatar
petemac
Someone had the same code.....look at the bottom post.
https://www.hdforums.com/forum/touri...ode-p0118.html
Old Sep 5, 2010 | 06:00 PM
shortride's Avatar
shortride
Thanks but I also read that post and checked the connector.
onemaverick
Apr 23, 2012 04:15 PM
trib
Sep 8, 2010 01:42 PM
1931jamesw
Sep 7, 2010 05:03 PM
FLH05
Apr 11, 2009 05:46 PM
catken
Dec 20, 2007 07:29 PM
