front brake pad
Old Sep 5, 2010 | 07:41 PM
langlois1's Avatar
langlois1
Question front brake pad
can anyone tell me why my front brake pedal is hard to prees down. and the bike does not good with the front brake. thanks.
Old Sep 5, 2010 | 07:43 PM
dawg's Avatar
dawg
Front brake pedal? There is a front brake lever and a rear brake pedal. Which one is giving you trouble?
Old Sep 5, 2010 | 07:57 PM
langlois1's Avatar
langlois1
rear brake pedal. hard as a rock.
Old Sep 5, 2010 | 08:08 PM
dawg's Avatar
dawg
Remove the lever and check the bushing. If that's not it, start looking at the plunger in the master cylinder.
Old Sep 5, 2010 | 08:32 PM
SteveO's Avatar
SteveO
If you have installed V&H tru-duals lately, the petal may be hitting the exhaust.
Dealer installed V&H tru-duals on my 08 Ultra SE3 and on the way home I barely had rear brakes, turns out they had reversed the washer under the trans causing the pipes to sit lower and contact the brake petal. Re-did everything myself and solved the problem. There only about 1/4" clearance between the brake petal and the exhaust when everything is aligned properly.
lostrider06
Dec 25, 2024 11:35 PM
wildhog7
Jul 25, 2014 10:26 AM
bigh8840
2014-2024 Touring Models
18
Apr 7, 2014 12:11 PM
langlois1
Sep 7, 2010 05:35 PM
bruce sg08
Jul 20, 2008 05:18 AM
