Fuel additives
Old Sep 9, 2010 | 08:23 AM
shortride's Avatar
shortride
I use an occasional fuel injector cleaner.
Old Oct 3, 2010 | 02:35 PM
Bigfishms's Avatar
Bigfishms
Hey, question, what's the difference between Stabil- Marine formula and reg stabil ? I use am little stabil in my gas tank if im not gonna ride for a couple of months i the winter/
should I use the marine formula? it says "ethanol formula on the container"
Old Oct 3, 2010 | 03:41 PM
Mike_68's Avatar
Mike_68
Originally Posted by relli
seafoam
Big +1 on Seafoam. I've been told that most fuelinjector and carb cleaners work by burning at a higher temp than gas/ethanol which will work somewhat over time. Seafoam, however actually removes the carbon and residue causing it to be taken out through the oil.
Old Oct 3, 2010 | 07:45 PM
The Old Man's Avatar
The Old Man
My Dad used to lay up outboard motors for the winter up in Maine 50 years ago. Aways squirted it into each cylnlinder and did a dry start with the plugs out to lube every thing up. I have never used it since. He swore by it though...........
Old Oct 3, 2010 | 08:40 PM
upstate tim's Avatar
upstate tim
Used MMO on carb'd bikes. Fuel only. Great for high mile bikes.
Tried it in my 06 RK and it left a stink on me. Guess the old bikes burned dirty enough for me not to notice the MMO stink. Probably will add some along with stabil for winter storage and fog the cylinders.
Old Oct 3, 2010 | 08:50 PM
Teardrop's Avatar
Teardrop
I either use Techron or Seafoam and have had good results with both. I usually treat my bike and Auto's about every 4 months.
Old Oct 3, 2010 | 10:42 PM
myred55's Avatar
myred55
Seafoam....
Old Oct 15, 2010 | 06:44 PM
okcjetmech's Avatar
okcjetmech
I run 100LL avgas in mine when ever I get the chance, and when using 91 pump gas I use "Rocket Fuel" additive only because I have 10.5:1 comp ratio I can tell if I stop running it...pings like a mother.........
Old Oct 15, 2010 | 07:42 PM
Punjabi Rider's Avatar
Punjabi Rider
Switch fuel co. often and use only premium , occasionally I use Chevron's Techron fuel injector cleaner .
Old Oct 15, 2010 | 09:15 PM
Port Dawg's Avatar
Port Dawg
I've replaced Stabil with Seafoam and my bike started right up the other day after sitting for 5 + months while I was deployed..this is on the VTX, don't see why I should change anything when I get the Road King
