Heat
Old Sep 10, 2010 | 10:14 AM
bwana1's Avatar
bwana1
The absolutely positively best way to lower the heat on an Ultra in the summertime is to remove the lowers.
Bwana
Old Sep 10, 2010 | 10:22 AM
roadgliderick's Avatar
roadgliderick
Originally Posted by BLK08ROCKERC
So are you guys seeing a difference in temps after installing these oil coolers compared to before? I just don't see how they work sitting still if no air is flowing over them. If you are running down the road the wind should be doing it's job cooling the motor right? I was thinking about installing one and then got to thinking to hard maybe?
it fan assited kicks on at 230 shuts off at 190. but your bike has so much black on it u wont need it cuz its faster. lol
Old Sep 10, 2010 | 10:26 AM
BLK08ROCKERC's Avatar
BLK08ROCKERC
Hahahaha! The only reason all that black is making it faster is because my wallet is getting lighter! Less weight to haul around!
I didn't realize it had a fan on it. May just go ahead and order it. How much is it $$ ?
Old Sep 10, 2010 | 10:35 AM
roadgliderick
dr vtwin will hook u up with a killer price ask for shawn or drew. should need help on the install let me know. ultra cool recommends using the switched wire that runs threw the head light. i ran mine to the brake switch which is a cleaner look and u dont see any wires. i think he sells them for $399.00 not sure good luck.
Old Sep 10, 2010 | 11:58 AM
nvsteve's Avatar
nvsteve
Bwana
Makes no difference when you're in traffic. My experience is it makes marginal difference when your moving except more air on your legs.
Old Sep 10, 2010 | 12:26 PM
bwana1's Avatar
bwana1
I beg to differ. I have run the gamut with oil temp cooling techniques: syn oil, oil cooler, true duals, stage 1 and SERT dyno tune. Pulling the lowers in the summer has dropped the oil temp on the highway more than the others combined. I can now climb a 10 mile hill at 75 mph and 95 degrees with the oil temp NEVER exceeding 130.
Bwana
Old Sep 10, 2010 | 12:42 PM
Aleslinger's Avatar
Aleslinger
The Jerry Rigs system also might help cool the oil and should make it easier to do an oil change. I don't have one, but it looks like a fine idea to me.
http://www.jerrysrigssystems.com/
Old Sep 10, 2010 | 01:16 PM
lionsm13's Avatar
lionsm13
Oil Bud Cooler for me, no wire cuttin'/splicin'.
www.budsbikerparts.net
Old Sep 10, 2010 | 01:27 PM
Guntoter's Avatar
Guntoter
Just don't put on the big engine fan Harley sells to go on the left side of the motor. It may cool the motor somewhat but it will make your right leg hotter the burning coals. This is while driving highway speeds. All that heat it blows from the engine goes right to your right leg.
Old Sep 10, 2010 | 04:55 PM
nvsteve's Avatar
nvsteve
Bwana
Assuming you meant 230 do you know what the temp was after all the mods but with the lowers on and vents open?
