2011 CVO Street vs 2010 Street Glide rear lights
Old Sep 15, 2010 | 08:39 PM
VT Hog's Avatar
VT Hog
Subscribed!
Old Sep 16, 2010 | 04:38 AM
RangeRat's Avatar
RangeRat
Originally Posted by craigeoh
Subscribed!
Me too.
Old Oct 6, 2010 | 12:07 PM
appliedhort's Avatar
appliedhort
4th Gear
I have a 2007 Street Glide and would like to do the same thing. Since I don't have the 200 rear tire, couldn't I just purchase the filler strips with the lights and harness assembly, remove the light bar and fill the holes, then have the rear fender color match painted? Also, anyone know if the gas tank and the speaker assembly in the lower fairings can be retrofitted to an '07?
Old Oct 6, 2010 | 12:36 PM
FFeric's Avatar
FFeric
I like those lights. I ordered a Sinister rear fender and I am looking for some lights. Are the HD lights seprate or are they build into the fender ir strips?
Old Oct 6, 2010 | 01:08 PM
Harleypingman's Avatar
Harleypingman
Originally Posted by appliedhort
I have a 2007 Street Glide and would like to do the same thing. Since I don't have the 200 rear tire, couldn't I just purchase the filler strips with the lights and harness assembly, remove the light bar and fill the holes, then have the rear fender color match painted? There aren't "filler strips;" it's a fascia--U-shaped, one piece plastic like the fascia on your Street Glide. Also, the '09 and newer fenders are wider, so using the CVO fascia on your fender will require that the fascia be narrowed. An HDF'er posted that he had this done on his '07 (?) by a painter and it looked great, but I didn't bookmark the thread. Also, anyone know if the gas tank and the speaker assembly in the lower fairings can be retrofitted to an '07? Don't know about the gas tank but it's unlikely since it's the six gallon tanke. The fairing lower speakers should work on vented lowers since the other part nos. of the fairing lowers on the 2011 CVO SG are the same--I'm waiting for the speaker boxes from HD and will (hopefully) install them soon.
Originally Posted by FFeric
I like those lights. I ordered a Sinister rear fender and I am looking for some lights. Are the HD lights seprate or are they build into the fender ir strips? If you check the link threads above, I believe there are part nos provided. The LED's are separate parts (left and right sides) and you could install them. The OEM HD fascia is frenched to accommodate the LED strip lights.
Good luck with your projects.
Carl
Old Oct 6, 2010 | 04:36 PM
mike1158's Avatar
mike1158
Originally Posted by Deuce Bigelow
easy install!
what did you do with the dimples and holes in the rear fender where the original light bar mounted?????
Old Oct 22, 2012 | 09:53 AM
Likarok's Avatar
Likarok
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Here is the link!
Old Oct 22, 2012 | 10:01 AM
bigdaddy33's Avatar
bigdaddy33
Nice job. Do the lights in the panels act as running, brake, directional or some combination?
Also, who's extended saddle bag kit did you use? Looks good.
easy install!
rodrocket
Screamin Eagle CVO Models
Apr 17, 2013 07:53 PM
32vld
Jul 17, 2012 10:20 AM
OlDusty
Nov 7, 2010 09:42 PM
Ironbarr
Jul 27, 2010 08:19 PM
SouthernAlberta
Dec 14, 2007 08:00 PM
