Wind deflectors AND lowers!
cass
-Dusty
With the fork deflectors on, and vents closed, we took off for our dealer, 110 miles away, on a day that was in the 70's. When we got there, I was shocked to see a temp of 279 degrees. On the way back, I opened the vents, and it still ran about 250 degrees by the time we got home (again, 110 miles).
Without the deflectors, hold your hand out into the airflow, and you will find the air collapses back right onto your engine, and causes some of the buffeting to the rider. With the deflectors, it doesn't collapse back until past the engine. Less buffeting to the rider, more heat to the engine.
The fork baffle that you installed prevents the hot air from evacuating around the heads, as it directs the air flow down, instead of under the tank. The parts manual recomends not running the baffle in the summer for that reason, "to keep the rider more comfortable." We have a fork baffle, and it works great preventing the updraft from the front of the gas tank hitting you square in the face, but it makes for more heat down by your legs.
The newest issue of American Iron has a blurb about the fork baffle, and the reason it's not on the recent Ultra's.
It should not take a rocket scientist to figure out that if you are blocking air
up front, you are blocking air from getting to the motor and running higher temps.
Good Job.
