Zumo Interface?
Old Sep 14, 2010 | 03:49 PM
jberg's Avatar
jberg
Default Zumo Interface?
Seems the new CVOs have a Zumo mount that interfaces with the audio system allowing the Zumo audio to be heard in all modes on the sound system.
It would be a great retro-fit item for older models.
Currently you need to plug into the aux input and select aux, thereby eliminating radio use. Anyone know anything about this?
Old Sep 14, 2010 | 04:00 PM
2WheelGlider's Avatar
2WheelGlider
HD has released the GPS interface as an available part in the accesory book. I think its about $150 option, and from what I understand it only works with the HD branded 660 or 665.
I am thinking seriously about getting it, but it doesnt look compatible with the hands free kit, but I can not find any information about it.
Old Sep 14, 2010 | 10:49 PM
jberg's Avatar
jberg
Just my luck it wouldn't work with the 550. Anyway, I've already sort of solved it with a Mix-It sound board which runs through the aux port with my Sirius.
Old Sep 15, 2010 | 12:02 AM
sifularson's Avatar
sifularson
I just bought the interface from Lakeshore for around $120. One of my Winter projects will be to install it and see if it works with my 550. I'll post my results . . . this Winter . . . Sorry.
Old Sep 19, 2010 | 10:40 AM
nmccanic's Avatar
nmccanic
Stage III
Well i found some place that they ask garmin if the interface would work with a garmin 660 or 665 and there answer was only with HD RoadTech because the soft ware is set up to put a signal to the module when a command is being made. This is what i found by searching for a answer why my garmin didn't work.
Old Sep 19, 2010 | 07:20 PM
tincup64's Avatar
tincup64
are the connections long enough to be used with handlebar mount? i know the description says dash mount.
thx - tin
Old Sep 19, 2010 | 07:36 PM
tincup64's Avatar
tincup64
just read that the cvo road glide uses the handlebar mount and has the interface. wonder if its a different part number.
Old Sep 20, 2010 | 06:26 AM
nmccanic's Avatar
nmccanic
Stage III
the gps cables are long enough to reach where you will mount the module if used.
Old Sep 20, 2010 | 07:01 PM
tincup64's Avatar
tincup64
from the handlebars? have you done it? this is great news, thank you. tin
Old Sep 20, 2010 | 07:15 PM
vzts4q's Avatar
vzts4q
Default Zumo interface
You still have to use the aux input if you want to use the MP3 player in the Zumo
Here is a link to a LONG thread on another forum.
http://www.cvoharley.com/smf/index.php?topic=52242.0
FenelonPaul
Dec 5, 2016 06:16 PM
hotshot
Jul 29, 2009 06:06 PM
tima
May 31, 2009 12:36 PM
Blacklion213
Oct 29, 2007 12:44 AM
jrp
Jul 24, 2005 11:29 PM
