View Poll Results: Compensator Upgrade?
I own a 2011
5.06%
I have upgraded to the SE Compensator under warranty
7.59%
I have upgraded to the SE Compensator at my own expense
24
30.38%
I plan to upgrade to the SE Compensator
28
35.44%
I have no plan to upgrade to the SE Compensator
11
13.92%
What's an SE Compensator?
7.59%
Voters: 79. You may not vote on this poll
Compensator Upgrade Poll
Old Sep 18, 2010 | 01:44 AM
davessworks's Avatar
davessworks
Default Compensator Upgrade Poll
Having read the compensator posts here I'm wondering how many have either upgraded or are thinking of upgrading to the SE compensator (and now original equipment on 2011 bikes). In the attached poll select "under warranty" if you got the dealer to do the labor and you received partial credit toward the cost "under warranty".
Old Sep 18, 2010 | 05:35 AM
cdestuck's Avatar
cdestuck
Yea, upgraded to a SE comp. at my own expense. Cost me 36,000 bucks!
Old Sep 18, 2010 | 05:48 AM
shortride's Avatar
shortride
This is one of those situations that if you don't completely understand what a compensator does or does not do.....as I do not, it make it a bit difficult to decide if replacing the compensator will correct some or all of the problems some riders have complainted about.
If a compensator does what it's designed to do, why are some have problems that other bikes of the same year and models are not having? What are other contributing factors if any?
Old Sep 18, 2010 | 06:00 AM
gs34doc's Avatar
gs34doc
Big Kahuna HDF Member
If you will go to this thread, there are a couple excellent explanations of the problem and also the workings of the compensator.
https://www.hdforums.com/forum/touri...mpensator.html
I changed mine out 35,000 miles ago and it remains the best inprovement I ever made.
Old Sep 18, 2010 | 06:29 AM
FATBOB.'s Avatar
FATBOB.
happy to hear i have it on my street glide 2011.The big difference i see is
that my street glide starts harder than my fatbob 2008.may be it is because
it is new..my fatbob was smooth when i would start the bike...if the upgrade
was done , well, i guess it is normal...
Old Sep 18, 2010 | 06:42 AM
lionsm13's Avatar
lionsm13
I've bought one for my 09, but have yet to instal it. That will happen though..
Old Sep 18, 2010 | 08:41 AM
Scorpion07's Avatar
Scorpion07
I just replaced mine and think it's a great upgrade. It smooths out all driveline pulses, helps soften throttle input after shifts, and if you have an early 6 speed, it helps smooth out the first gear starts (high first gear ratio).
Having said that, I also notice that I've lost some of the snap during initial throttle roll on, which kinda deadens the feel a little. Not bad, but noticeable. I still think it's a worthwhile tradeoff on my 07 though.
As far as why it effects some bikes and not others, besides manufacturing tolerance's and stack up, some people just don't worry about that stuff. Kinda wish I could be more like that sometimes......
Old Sep 18, 2010 | 09:14 AM
nemick's Avatar
nemick
I think it's worth noting that very few of the stock compensators actually fail. A few have had the retaining bolt come loose, etc. In my case, the stock compensator was in perfect condition, was tight and in every respect it was perfect, within it's own limitations. Unfortunately, it's limitations are massive. It is an inadequate component for the job it is supposed to do. Many people will not care about this and will even consider it's uselessness to be 'normal'. As I have stated in a previous post, it is difficult to imagine that the 'stock' compensator and the 'SE' compensator were designed to do the same thing. That's how big the differences in design are!
To each their own, but to this day, installing the SE compensator remains the single most beneficial upgrade I have done to my '09 Ultra.
Old Sep 18, 2010 | 12:11 PM
Bigiron's Avatar
Bigiron
Need to start another poll: How many have filed a safety complaint with the NHTSA? Last time I checked, there were only two, mine and one other. If enough complaints are made, the Feds will really lean on Harley Davidson to fix the problem. Ask Totota.
Old Sep 19, 2010 | 01:30 PM
shortride's Avatar
shortride
What are the potential safety concerns that could involve the NHTSA?
