Bike died
Old Sep 20, 2010 | 07:44 AM
07JakeelwoodHD's Avatar
07JakeelwoodHD
Default Bike died
Last night a friend called me looking for help he was comming home riding on the Hwy and his bike 08 Street Glide just died the bike turns over but wont start any ideas had to put bike on the trailer to get him home..
Old Sep 20, 2010 | 08:20 AM
Scorpion07's Avatar
Scorpion07
Mine had the same issue after shutting it down, and trying to restart. In my case it was the pressure regulator at the fuel line quick release at the bottom left side of the tank.
Just pull up on the chrome ring and down on the fuel line to disconnect, reverse to reconnect.
It relieves the pressure at the quick connect and if that's it, it should start right up..
In early 08, the fuel regulator/filter (in the tank) might have a crack in it. Recalled part for that model.
Old Sep 20, 2010 | 08:30 AM
petemac's Avatar
petemac
Have him check to see if he's getting any codes.
Old Sep 20, 2010 | 02:54 PM
BBStacker's Avatar
BBStacker
Did it "just" quit running or did it sputter to stop? Makes a difference.
Sputter so to speak is a fuel issue.
Just quitting is an electrical issue.
Cranks but no go? Spark and or as was mentioned fuel.
Good hunting!
Old Sep 21, 2010 | 07:22 AM
07JakeelwoodHD
From what I was told it just shut off will crank but wont start..took the bike to the dealer will let you know what issue is
Old Sep 21, 2010 | 04:45 PM
07JakeelwoodHD
Gas filter
Old Sep 21, 2010 | 05:21 PM
petemac's Avatar
petemac
There was a SB on the fuel filter housing cracking on the '08's. This should be covered under warranty.
Old Sep 22, 2010 | 09:07 AM
07JakeelwoodHD
There claiming it was done but the bike shouldnt need a filter with under 10k he is trying to get the dealer to fix it under the SB
Old Sep 22, 2010 | 09:10 AM
petemac's Avatar
petemac
If they give him a hard time tell him to call the MOCO and ask them to help out. It is a known problem so they should help out on this.
Old Sep 23, 2010 | 05:13 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Should'a heard the fuel pump running non-stop.
