Hot pipes on a Ultra?
Old Sep 22, 2010 | 07:17 PM
blackswampbiker's Avatar
blackswampbiker
Default Hot pipes on a Ultra?
My Dad just bought a 2007 Ultra it has Samson slip ons and a power commander. The pipes run very hot, hot enough it burns the back of the riders legs and the passangers legs when their feet are on the floor boards. Do the Ultras run this hot or is the power commander leaning it out to much or any other ideas?
Old Sep 22, 2010 | 07:23 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
in my opinion the 07 is the hottest running bike they make.power commander cooled mine down alot,i would look into a different map or better yet seek out a good tuner in your area and get it on the dyno. there was a thread in here awhile back about a good dyno shop in nw ohio.
Old Sep 22, 2010 | 08:05 PM
FLHP1034ME's Avatar
FLHP1034ME
I could be wrong....but if you are still running stock cams, regardless of tuning device, you are probably most likely to have some heat issues. I have an 07 FLHP. The cure was Andrews 54h's and TMAT. I was always under the impression that the cams are the primary culprit and that the EPA mandated tune added to this. Once again, could be wrong. I am not sure how you you can make the statement that the 07's were the "hottest". What changed in 08-09-10 now 11? Did the EPA lighten up on the MOCO?
I think that as long as you have stock cams in your bike you are going to have a "hot runnin' scoot". Regardless of tuning device.
Old Sep 22, 2010 | 08:09 PM
bigdumbnoitall00
think after all the complaints harley did some map tweekin and added emits then moved the pipes down low so u dont feel the heat.
Old Sep 22, 2010 | 08:27 PM
arealinvestor's Avatar
arealinvestor
Check the tune!!!
Old Sep 23, 2010 | 12:16 PM
Samson_info's Avatar
Samson_info
Former Sponsor
Originally Posted by arealinvestor
Check the tune!!!
it sounds like it is running much too lean.
JR
Old Sep 23, 2010 | 01:04 PM
sargek's Avatar
sargek
Check your Y-Pipe to make sure it's not cracked - that will send a nice hot jet of exhaust at one of your thighs. My PC-III is using a canned map which is far better than the stock set up, but a dyno tune will help too.
Old Sep 23, 2010 | 01:22 PM
88racing's Avatar
88racing
Try to contact Fuel MOTO.
Tell them what's going on.
They might have a better map for the power commander.
rollin_thunder
Jul 20, 2014 12:53 PM
rollin_thunder
Jul 20, 2014 12:48 PM
slammer66
Jul 19, 2012 07:05 PM
mastied
Apr 24, 2012 07:02 AM
ropd0184
Oct 7, 2009 09:26 PM
