Going to stage 1 with my bike and using the SE Super Race tuner. I see 2 available maps for this configuration and curious if anyone knows the differences. The latter seems to be relatively new and the one I'm starting with.
2010-11 Touring:
1690 ''All Market' SE A/C & Race Exhaust FT O.E. O.E. O.E. 009FZ002
2011 Touring:
1690 ''All Market' SE A/C & Race Exhaust FT O.E. O.E. O.E. 44AAO002
open the maps up in the race tuner program ve tables and timing are probably different and the cam my be different ill post this the add to iut going to look at maps
I'm wondering the same thing. I did notice that the 009fz002 file has to be selected manually. If you put in the ECM PN, Year = 12, Family = touring, Model = any 103, it gives a list of stored cal. files all starting with044. Why doesn't show the 009fz002? These two, 009fz002 & 044aao03, are so similar it makes you wonder how they come up with the stored list that shows one but not the other.
There is little differences in the maps. When I connected my '12 FLHTX to the SEPST it automatically selected the 44AAO002 map. So I have been doing smart tunes using that map.
009FZ002.dt0 Application: 2010 'All Market' Touring Exhaust with O2 Sensors
Configuration: 1690 SE A/C & Race Exhaust
Components:
- SE Air Cleaner and Breather Kit P/N 29440-99D
- SE Big Bore Cylinders P/N 16546-99 or 16549-99
- SE Big Bore Flat Top Pistons P/N 21966-07
- Race Exhaust
- ACR DISABLED 44AAO002 for some reason i cant find this file
I think the level 44 calibrations might have something to do with the TBW or the newer type of O2 sensor. Not sure when they went with the new style but think it was 2010.
The FZ map is the newest version for the 103. Make sure you turn "ON" the ACR and the Smart Tune if you plan on using the smart tune feature. If you have done a basic stage 1, air cleaner and mufflers, all you really need to do is highlight all the "Bold" boxes and change the value to 14.1 afr. Then use the smart tune if your heart desires.
