Bicycle pump cause damage to rear shocks?
Old Sep 29, 2010 | 07:59 AM
FXSTS-88's Avatar
FXSTS-88
I've used a 'bicycle' hand pump for 25 years w/o any problems!!
The problem isn't with the pump, it's usually with the 'power device'!!!
Those little hand held bike pumps work as well as that $40 'suspension pump' at 1/4 the cost. Only good thing about the 'suspension pumps' is the built-in pressure gauge.
Old Sep 29, 2010 | 08:12 AM
Ricochet59's Avatar
Ricochet59
I have a pump on the way. Got a good price on eBay, $29.95 with free shipping. eBay item #290339057837 Air Shock Pump Harley Touring Road King Street Glide
Item title: Air Shock Pump Harley Touring Road King Street Glide
Web Address: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290339057837
Old Sep 29, 2010 | 08:38 AM
Texas Fat Boy's Avatar
Texas Fat Boy
Originally Posted by motorlessons
There are 2 related problems.
The first is that you're dealing with a very small volume system. Therefore even a bicycle pump can overpressure the shocks fairly easily. The damage comes because the weak link in the system is the seals in the shocks. If you damage them, they aren't serviceable.
Second is that the Harley pump (or any suspension pump), is what's called a "zero-loss" pump. The flexible tube acts as a pressure chamber, and the fitting is specially designed to allow the Schrader valve to close, before it breaks the connection. This way the gauge reading is exactly what remains in the system when you disconnect the pump. A bicycle pump loses air when you disconnect the hose from the valve. The low volume of the suspension means this amount of loss will have a significant effect on the pressure remaining in the shocks.
Harris
Denver, CO
www.youtube.com/conedown
What he said ^
Old Sep 29, 2010 | 08:50 AM
parachuter's Avatar
parachuter
You would think if the pump was that important, Harley would supply one with delivery. Can't miss out on the accessory sales though.
Old Sep 29, 2010 | 09:02 AM
monumaker's Avatar
monumaker
I think I may have blown my seal with a small air tank. How can I tell for sure?
Old Sep 29, 2010 | 09:21 AM
FXSTS-88's Avatar
FXSTS-88
When you pump them up, does the pressure stay or does it leak down shortly after you apply pressure? If it leaks down then you have a seal problem...somewhere.
Old Sep 29, 2010 | 09:43 AM
grbrown's Avatar
grbrown
Cool
I used a bicycle pump for almost 20 years! I had a shorty pump with an adapter hose for airbeds. Total cost peanuts.
This is one of those topics in danger of creating an internet myth. The fancy pumps were not readily available when I bought my bike new back in 1990, so a bicycle pump it had to be. The 'proper' pump is great to use, but not necessary and neither pump will not cause any harm if used with care.
Old Sep 29, 2010 | 09:47 AM
Certified Drunk's Avatar
Certified Drunk
That could happen if you used a bicycle tire pump and not the low pressure bicycle shock pump!....which is the same as the Harley pump!
Old Sep 29, 2010 | 09:50 AM
KingCripps's Avatar
KingCripps
Ok, so why not use a compressor?
I have done it in the past, before I bought the HD pump. I bleed the tank down to 50 psi and then fill the shocks. As long as you don't go over the max allowed for the shocks, you should be fine. The HD pump is easier because you get the exact pressure that the gauge reads with no bleed down as you are disconnecting.
Old Sep 29, 2010 | 10:19 AM
hoethree's Avatar
hoethree
Thanks for the Ebay lead Ricochet59! Was planning to buy a pump and you saved me some pesos!
