Adjustable pushrods help please
Old Oct 10, 2010 | 09:23 PM
masterblaster's Avatar
masterblaster
Default Adjustable pushrods help please
Installed the 570 ES cams today , sdjusted acording to procedure with each cyl at TDC of compression stroke, did the 3.2 turns after finger tight on a 32 TPI GMR adjustable pudhrod kit, waited 15 min for bleeddown and it worked perfect can turn with finger no slack after each 15 minute period. Now after doing the each cyl individually I turned the engine via back tire, I check the rods again all spin except one after each revolution. Different one is tight each time. Does this sound right?
Old Oct 10, 2010 | 09:46 PM
SICKBAGGER's Avatar
SICKBAGGER
Could be possible as the duration / lap can be forcing a load on one of them. Do they all spin feely on TDC of each cycle of adjustment? The only way to know is adjusted on TDC for each one.
Old Oct 10, 2010 | 09:48 PM
masterblaster
Yes they spin freely on the TDC cycle. but the ones taht are not TDC are tight.
Old Oct 10, 2010 | 10:11 PM
SICKBAGGER's Avatar
SICKBAGGER
That is the way she will work they are all invarious stages of the cycles. If you have adjusted them per the directions and on TDC all of them free up you should be ok.
Old Oct 11, 2010 | 01:34 AM
Garcou's Avatar
Garcou
Yep what he said!
Old Oct 11, 2010 | 05:08 AM
asm481's Avatar
asm481
The one not spinning freely is the one pushing the valve at the moment. If they are good at TDC you are good to go. No harm in starting over if you are unsure. Loosen them all up at TDC and take another shot at it.
Old Oct 11, 2010 | 05:11 AM
masterblaster
Thanks gents I will crank the motor over today. hope it does not grenade.
Old Oct 11, 2010 | 06:47 AM
Jinks's Avatar
Jinks
Top Dead Center of the compression stroke the push rod is on the heel (base circle) of the cam. That's the point where they should rotate easily with your fingers. Anywhere else on the stroke & the push rod is either on the ramp or on the lobe of the cam & will be impossible to rotate. You would only be wrong if you *could* rotate all of them at the same time.
Road Star
Engine Mechanical Topics
May 12, 2017 11:27 AM
cycler
Oct 6, 2016 05:41 AM
AllenW
Exhaust System Topics
11
Apr 23, 2013 08:33 AM
LOOPNERS
Jul 14, 2009 10:55 PM
Z
Aug 2, 2006 01:07 AM
