Checking Primary Fluid Level
Old Sep 16, 2006 | 01:20 PM
06EGlide's Avatar
06EGlide
Default Checking Primary Fluid Level
I know the book says that the Primary oil level should be at the bottom of the Derby cover. But putting the bike level, the oil level is even with the Cam Chain Inspection cover. Why does the Derby cover have to come off to check the level? It's much easier to just take off the Cam Chain Inspection cover to check the chain tension, and refill with oil. Am I looking at something wrong?
Old Sep 16, 2006 | 01:30 PM
MACK's Avatar
MACK
Default RE: Checking Primary Fluid Level
THAT LOCATION IS A HIGHER POINT IN THE PRIMARY AND YOU CANNOT GET AN ACCURATE CHECK OF THE FLUID LEVEL.
Old Sep 16, 2006 | 02:00 PM
rhinoevans's Avatar
rhinoevans
Test1
Old Sep 16, 2006 | 08:08 PM
2005UltraNC's Avatar
2005UltraNC
Unless it's leaking, why check it? I put in the recommended amount and don't touch it for 5000 miles when I change it. Also, using the Formula+ - like it better than the syn oils.
Old Sep 16, 2006 | 08:35 PM
Shovelhead Bob's Avatar
Shovelhead Bob
The book does not say to bring the level to the bottom of the derby cover......
It shows you that it goes to the BOTTOM OF THE DIAPHRAM SPRING of the clutch....
You got a Clymer manual or something???????
Old Sep 16, 2006 | 08:38 PM
glide's Avatar
glide
That would be a lot of oil if it was to the bottom of the derby cover, probably couldn't shift the bike or find neutral at all. The bottom of the diaphram spring like Bob said is where it belongs.
Old Sep 17, 2006 | 11:04 AM
1flhtk4me's Avatar
1flhtk4me
If your in doubt,drain and replace with 32oz.
Curt1953
Aug 16, 2015 03:11 PM
Badass67stang
Sep 3, 2010 02:32 PM
deepsea
Mar 7, 2010 08:37 PM
Thomto
Aug 13, 2009 09:43 PM
nb472
Oct 6, 2006 08:39 PM
