transmission question
Old Mar 7, 2010 | 04:55 PM
deepsea's Avatar
deepsea
Default transmission question
New guy to street bikes. I want to change my transmission oil and check the primary chain because my manuel says that may be why it is jerky at low speeds. Between the manuel and reading the forums I am a little confused. If I drain the oil and stand the bike upright to fill from the primary cover, have I changed the oil in both the transmission and the primary or are they two separate areas?
Old Mar 7, 2010 | 05:00 PM
volksrod2110's Avatar
volksrod2110
If you are talking Harley, it has separate oil for the transmission and primary.
Let us know what you are working with.
Old Mar 7, 2010 | 05:24 PM
cHarley's Avatar
cHarley
WRONG - SORRY dude but this is the Sportster Section.
The Sporty has a shared Primary/Tranny. 1 quart of fluid takes care of both.
Old Mar 7, 2010 | 05:27 PM
cHarley's Avatar
cHarley
You don't need to remove the primary cover to refill the primary/tranny oil. You can add it through the chain inspection cover. That's much easier and just 2 screws, and you'll have that cover off to adjust the chain.
Old Mar 7, 2010 | 06:49 PM
volksrod2110
Thats why I asked what he was working with. Guess I should pay closer attention to what section is listed when I look at the new posts.
Old Mar 7, 2010 | 08:37 PM
SportyPig's Avatar
SportyPig
Changing the tranny fluid will not help with the bike being Jerky at slow speeds. It does however sound like a primary chain that needs adjusting.
Midpegs
May 21, 2019 03:45 PM
Curt1953
Aug 16, 2015 03:11 PM
Slyvest
Jun 5, 2014 11:28 PM
Thomto
Aug 13, 2009 09:43 PM
mayfiebl
11
Oct 6, 2007 09:34 AM
