Primary oil .
Old May 20, 2019 | 04:11 AM
Midpegs's Avatar
Midpegs
Default Primary oil .
A quick question . Why all the drama about oil levels in the primary case when you do a complete oil change ? It takes exactly a quart , so why not just pour in a quart and be done with it . You don't even have to remove the Derby cover because it can easily poured in through the chain inspection cover .Am I missing something here ? As a footnote , I wonder why HD couldn't just put a sight glass in the primary cover so that I don't have to remove my foot peg once a month .
Old May 20, 2019 | 05:33 AM
blackxpress's Avatar
blackxpress
Newer bikes don’t have inspection covers and they don’t all hold exactly one quart. My 17 Heritage holds 36 ounces, which works out good since the trans takes 28 ounces. I put 28 in the trans, then pour a full qt. plus the leftover 4 ounces into the primary. Works great as long as I use the same lube in both trans and primary.
Old May 20, 2019 | 05:41 AM
CoolBreeze3646's Avatar
CoolBreeze3646
I think the OP is talking about a Sportster. Engine oil & trans oil use the same hole on Sportster's.
Old May 20, 2019 | 05:53 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What model and year are you talking about?
Old May 20, 2019 | 06:15 AM
apache snow's Avatar
apache snow
Yeah, I have always put in a quart when changing the trans oil and have never had any issues. I don't intend to fix what isn't broken.
Old May 20, 2019 | 06:46 AM
Midpegs's Avatar
Midpegs
Originally Posted by dan89flstc
what model and year are you talking about?
2004 xl 1200 r
Old May 20, 2019 | 07:17 AM
Kenny94945's Avatar
Kenny94945
For the OP, post 5 sums it up.
Many do as you've written...pour 1 qt through primary chain inspection hole.
The debate?
Maybe because the service guide does not offer that re-fill procedure as an option?
Without HD "blessing" we default to the remove derby cover procedure.
Is there a benefit to removing the derby?
I don't think so.
Most of he clutch or gears are not visible, a few dollars for O-rings is extra cost, possibility of a clutch adjustment error and torx derby screws damage.
I really don't see a benefit other than viewing the exact level of re-filled oil in the case.
Old May 20, 2019 | 12:15 PM
John Harper's Avatar
John Harper
No, some people are just ****, and think an extra ounce splashing around will destroy their transmission. Same people that use a torque wrench on the tiniest of bolts, or need a gear shift light to tell them when to change gears.. Or, a low fuel light to tell them not to run out of gas.
John
Old May 20, 2019 | 12:46 PM
whylee's Avatar
whylee
John
Exactly, I have not used a torque wrench on a Harley except for major motor parts and have never had any issues for 40 years. Nor have I seen any issues except from some ham fisted people trying to over tighten bolts.
Old May 20, 2019 | 01:03 PM
Midpegs's Avatar
Midpegs
Default Thanks !
Thanks everyone . Seems like common sense prevails . I've owned and worked on my bikes for 40 years but this is my first Harley so I guess there is a tendency to do things by the book at first . The thing is though , the main purpose of the book seems to be to encourage the owner to have all their servicing done by a Harley dealership. So it's a quart out and a quart in , simple. Any book that contains 80+ warnings about things that could result in serious injury or death probably shouldn't be taken too seriously . 😀
