Primary oil .
Old May 21, 2019 | 10:19 AM
Midpegs's Avatar
Midpegs
Originally Posted by Andy from Sandy
It makes sense to me that while the motorcycle is in a position to do it why not check the clutch adjustment and primary chain at the same time as changing the primary oil?
Will do, but I can do that through the primary chain inspection cover anyway . It was alright 400 miles ago .
Old May 21, 2019 | 02:33 PM
Midpegs's Avatar
Midpegs
Default Job done
OK , job done . I rode it a few miles , dropped the oil , removed the chain inspection cover , checked the chain ( all good ) then with the use of a modified funnel I slowly poured in a quart of Drag Specialities Sportster Gear and Chain case Oil for Sportsters ( you can't get more specific than that ! ) And that's it . What I did find interesting was what came out of the chain case . It was red in colour and even when cooled it was a bit thinner than what went in . I'm guessing this was ATF . One thing I've learned from this exercise is that if you asked a hundred experts what oil goes in a Sportster you are very likely to get a hundred answers ! Oh yeah, very little magnetic sludge on the drain plug , which was nice.
Old May 21, 2019 | 02:43 PM
apache snow's Avatar
apache snow
You done good.
Old May 21, 2019 | 03:05 PM
John Harper's Avatar
John Harper
My Bel Ray Sport Transmission oil is red.
John
Old May 21, 2019 | 03:45 PM
TStephen's Avatar
TStephen
Originally Posted by Midpegs
OK , job done . I rode it a few miles , dropped the oil , removed the chain inspection cover , checked the chain ( all good ) then with the use of a modified funnel I slowly poured in a quart of Drag Specialities Sportster Gear and Chain case Oil for Sportsters ( you can't get more specific than that ! ) And that's it . What I did find interesting was what came out of the chain case . It was red in colour and even when cooled it was a bit thinner than what went in . I'm guessing this was ATF . One thing I've learned from this exercise is that if you asked a hundred experts average bike owners.what oil goes in a Sportster you are very likely to get a hundred answers ! Oh yeah, very little magnetic sludge on the drain plug , which was nice.
Fixed it for ya.
Sounds like you did it right, and DS stuff is usually pretty good.
Curt1953
Aug 16, 2015 03:11 PM
jbyun
Sep 7, 2011 08:40 PM
deepsea
Mar 7, 2010 08:37 PM
hawgsickle
Oct 28, 2009 04:05 AM
mayfiebl
11
Oct 6, 2007 09:34 AM
