Need help with check engine codes
Old May 21, 2019 | 02:11 PM
Ian Gillette's Avatar
Ian Gillette
Default Need help with check engine codes
Just replaced the battery in my 2016 iron 883 got it running after about 1.5 years drained the fuel filled it back with premium. It runs but not great throttle is sticky, exhaust sounds clogged and I'm getting tons of codes please help!
The codes are all fuel/air related, map sensor, speed sensor, o2 sensor. They are p0107, p0131, p0151, p0374, p0503, p0506, p0641And pn 001255-01, also b2123, b2271 any suggestions?
Old May 22, 2019 | 04:52 AM
HotRod917's Avatar
HotRod917
p0107 : MAP (Manifold absolute pressure) sensor signal low
p0131, p0151: Both O2 sensors voltage low
p0374: CKP (Crank position sensor) sync error
p0503: VSS (Vehicle speed sensor) inconsistent signal
p0506: IAC (Idle air controller) system rpm low than expected
p0641: 5V reference1 out of range
pn 001255-01: ??
b2123 : Starter Output shorted low
b2271: BCM Low Voltage
Should have at least cleaned the Air filter before starting the bike after that long..anywho, clear the codes..check electrical connections, power cycle a couple of times, operate the switches and cycle through the turn signals, horn, high/low beam etc, check the engine and primary oils for condensation(if any, stop right there) ..start the bike without the Air filter, see what codes come up, report back. Good luck
53 pan
Sep 13, 2012 08:18 AM
wazapng
Mar 29, 2012 05:54 PM
virginiajoe
Jan 3, 2011 07:12 PM
nkauf21
Aug 15, 2010 04:08 PM
jebbarry
Aug 15, 2009 03:18 AM
