2010 Street Glide Exaust
Old Oct 19, 2010 | 10:42 PM
Darrell433's Avatar
Darrell433
6th Gear
Question 2010 flhx
I want to change my pipes also. I thought the CAT was required and would not pass inspection without it. I am considering just going with a V&H Hi Output Slip On for my 2 into 1 setup. Never heard of FatCats. If all a person is doing is changing the slip on, is remapping required or will it run too lean. If I have to have it remapped, do you think I should go with a Stage 1 filter? Or if the CAT is not a state requirement and I have to have a remap, should I just replace the whole system with something like the V&H Pro Pipe Hi Output? Really like the sound. All comments are welcome. Thanks
Old Oct 19, 2010 | 11:01 PM
NoCoLoco's Avatar
NoCoLoco
Originally Posted by xcelr8
Screaming Eagle.......designed by the people who designed your bike.
...and restricted by the same organization responsible for making your stock Harley run HOT and sound weak.
Old Oct 19, 2010 | 11:16 PM
G20's Avatar
G20
i just installed a Fuel Moto programed PC-V, Fuel Moto air cleaner, and Jackpot Powertube. I am very pleased with both the sound and performance gains.
Old Oct 19, 2010 | 11:27 PM
Torqueinc's Avatar
Torqueinc
Funny and true......the folks running screamin beagle are a lil on the clueless side at times.
Vance and hines propipe chrome
Old Oct 19, 2010 | 11:37 PM
Inspector 12's Avatar
Inspector 12
One of the beauties of the D&D Boss Fatcat is that it is designed so that if you install a high performance air cleaner kit and the Boss Fatcat you do not need a tuner or down load for it to work. Check out D&D's web site. As noted, great folks to work with. It produced great results as part of my stage II 103 project.
Old Oct 20, 2010 | 05:56 AM
mjb765's Avatar
mjb765
You may not absolutely NEED a tuner--which is true with most exhaust upgrades, but if you want to the bike to truly run better and cooler a tuner is the answer. The factory O2 sensors with compensate for most exhaust and AC upgrades, but it will only put the bike back to the stock A/F ratio, which is very lean due to EPA regs to begin with.
Old Oct 20, 2010 | 06:00 AM
glockholiday's Avatar
glockholiday
When I get my Street Glide I'm going with the V&H Pro Pipe HO 2to1, 2nd would be the D&D.
Old Oct 20, 2010 | 06:04 AM
xcelr8's Avatar
xcelr8
Originally Posted by Torqueinc
Funny and true......the folks running screamin beagle are a lil on the clueless side at times.:
What's really funny is that you feel the MOCO builds a bike that you are willing to drop 20+k on, but they are not smart enough to build a muffler. Check out their website re: exhaust R&D.
I was at the dealer the other day, and they had just finished putting a Rhinehart true dual system on an '11 Ultra Road Glide. Sounded awful
The SE system on my bike has a deep mellow sound, and there are no heat issues at all..
Old Oct 20, 2010 | 12:35 PM
augystyle's Avatar
augystyle
Stage II
Default thanks for the help
Thank you everyone for your advice. This was my first post and will be back for more help in the future.
Old Oct 20, 2010 | 01:26 PM
tat2fatboy's Avatar
tat2fatboy
i did the fuel moto stage 1 with the powertube slip on couldnt be more satisfied
