Do fairing lowers provide better weather protection than soft lowers?
Old Oct 21, 2010 | 07:37 PM
SteveO's Avatar
SteveO
DDM502001 is right on. I leave mine on all year long, helps keep the hot engine air off you in the summer, smooths out the air flow over the bike, bike actually runs cooler in the summer with them on.
Old Oct 21, 2010 | 07:43 PM
leicafish's Avatar
leicafish
I use the hard lowers on my Road King and Street Glide. Hot and Cold weather.
To me it is no so much the issue of warmth, (that is a side effect) but the difference of doing 300 vs 500 miles.
Attached Thumbnails Do fairing lowers provide better weather protection than soft lowers?-img00172.jpg   Do fairing lowers provide better weather protection than soft lowers?-hog-vd-4.jpg
Old Oct 21, 2010 | 07:56 PM
ronn39's Avatar
ronn39
My RGU came with them, and they were new to me. Need to rotate the slots open in the heat, close them up in the cold and wet. My previous ride, an RK, wasn't a lot of fun in the rain... my legs (and socks) would get soaked. I've been caught in the rain twice, so far, on the new ride (sudden showers pop up every afternoon in the summer). Closed up the vents and kept on going, and I was amazed to arrive home with dry pants (and socks) for a change. Yeah, they work!
Old Oct 21, 2010 | 08:00 PM
Slash's Avatar
Slash
Some of you are saying the motor runs cooler in hot weather with the hard lowers on ???
Haven't taken mine off my EGlide but if what you're saying's true it's a surprise to me...
Old Oct 21, 2010 | 10:18 PM
Mick's Avatar
Mick
I had soft lowers on my 06 FLHT and they worked as advertised , but as mentioned , they were pretty bad aerodynamically at higher speeds.
I felt like I was pushing a fair sized wall of air when going into the wind.
I had a chance to get color matched lowers for the 06 , so I ran them for a while and sold my soft lowers to a HOG member.
The HOG member loved them and still does 2 years later.
I feel the hard lowers do the same job as the soft ones , but they look better , handle better , and as mentioned , don't make the engine run hotter in the summer.
I removed the vents for the summer and my legs were much cooler afterwards.
My 09 Ultra came with them so I knew what to expect , and I still like them alot.
On the 09 , I removed the vents , cut away the material from the engine side of the vent , from the support inward.
This allows about 2" more airflow than stock (when open) and protects just fine(when closed) when it's below 50 degrees.
About the only thing that gets wet are my knees in a driving rain with the hard lowers.
Mick
Old Oct 22, 2010 | 12:45 PM
ofuzz_2000's Avatar
ofuzz_2000
I have used them both. The soft fairing seem to funnel the air to your chest. I prefer the hard fairing hands down. You won't be sorry.
Old Oct 22, 2010 | 02:54 PM
andyp's Avatar
andyp
The hard vented lowers will raise engine temps in hot weather,above 90 degrees, I remove mine in summer months. My oil temps are 20-30 degrees hotter with them on.
Old Oct 22, 2010 | 07:23 PM
Twinrider's Avatar
Twinrider
Thanks for all the helpful comments. I decided to get the hard lowers and the detachable kit. I'll probably have the hard lowers on from October through April, and keep the soft lowers I have in the side bag for sudden rain storms in summer.
Anyone have an opinion on the locking doors? $175 seems like a lot for a couple piece of plastic and two barrel locks
Old Oct 22, 2010 | 08:40 PM
roadhog96's Avatar
roadhog96
Anyone have some pictures to post with hard lowers on a Road King. I'd like to see what they look like. I've seen the soft ones but never the hard. Thanks
Old Oct 22, 2010 | 09:23 PM
Twinrider's Avatar
Twinrider
Leicafish's (post 12)
