pingle shifter shaft
Old 10-22-2010, 07:10 PM
SPARKY01's Avatar
SPARKY01
SPARKY01 is offline
Question pingle shifter shaft
just wondering if anybody has used this part. mine rattles around and drives me nuts, especially @ idle. hope its money well spent.
Old 10-22-2010, 08:16 PM
Dionicio's Avatar
Dionicio
Dionicio is offline
Never have used it, but it look's like a good product so I am going to order it. My shifter also rattles and it's a hassle taking it apart to grease it. Thought about putting a grease zerk between the shifter bushings, but I just don't want to drill into the inner primary case.
Old 10-23-2010, 04:22 AM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
There is a rubber bushing between the case and the shaft lever if you loosen the bolt and slide the shaft lever tighter against the rubber it will tighten the shaft up a bit, did this to mine stop the rattle
Old 10-23-2010, 08:21 AM
SPARKY01's Avatar
SPARKY01
SPARKY01 is offline
hmmm! not on mine!! what a suprise!!
monkey sammich
06-15-2021 12:20 AM
tsigwing
04-05-2019 07:14 AM
PFR-Captain
11-13-2014 07:46 PM
albngore
01-10-2012 08:44 PM
zubaugh
04-26-2008 01:25 PM
Quick Reply: pingle shifter shaft
