Shift shaft(?) replacement?
Old Sep 15, 2011 | 09:29 PM
monkey sammich's Avatar
monkey sammich
Default Shift shaft(?) replacement?
I guess that's what it's called. It's the splined shaft that the shift levers connect to. The splines for the heel lever have somehow managed to allow the shifter to slip. I don't get that.
Anyway, to replace it, would the inner and outer primary have to come off, or does it come apart in some way?
Old Sep 15, 2011 | 09:39 PM
tenn.vol.'s Avatar
tenn.vol.
Check out the www.betterlever.com..
They have a u-tube video also.. Tenn.Vol.
Old Sep 15, 2011 | 09:48 PM
flhtupser's Avatar
flhtupser
Try moving it in or out just a bit on the shaft to see if you can get it to grip better. I had to trim the rubber bushing between the housing and shift lever so I could move them both in on the shaft and took care of the problem. Also it's probably the lever splines that are worn and not the shaft.
Old Sep 15, 2011 | 09:54 PM
2012UltraLimited's Avatar
2012UltraLimited
I just had this problem with the shifter falling when driving and thought it was the shifter shaft. Turned out all it was to fix it was to remove the shifter and clean the shaft and reinstall. good luck.
Old Sep 15, 2011 | 10:23 PM
Eyespy's Avatar
Eyespy
From: Southern California High Desert, here and there....
The splined shaft is a hard steel. The lever is a softer material and designed to be the one that wears out, not the splined shaft.
Old Sep 16, 2011 | 06:41 AM
1flhtk4me's Avatar
1flhtk4me
Depends on what RC scale the material was heat treated to.
Could still be soft compared to other hardened materials.
Old Sep 16, 2011 | 07:03 AM
lksmitty's Avatar
lksmitty
You don't have to remove the primary to remove the shaft...there's a bolt that holds the shifting rod on just like the shift levers. Loosen all three and you can pull out the shifter shaft.
Old Sep 16, 2011 | 07:41 AM
monkey sammich
I would have thought this to be the case, but I can feel where the splines are worn/pushed down in one area as compared to another.
Next boggle is how in the hell does the heel shift lever, which mates into these splines all around, slip partially around the shaft? Somehow, it appears to have done so.
Old Sep 16, 2011 | 11:38 AM
EddieBlaize's Avatar
EddieBlaize
You need to take the bolts all the way out (on the levers). loose won't cut it, because of the groove in the shaft. At least on my '09...
Old Sep 16, 2011 | 12:04 PM
lkr0's Avatar
lkr0
true bolts have to come all the way out; easy fix -- I just purchased the spline from HD i think it was $24.00
