Shift shaft(?) replacement?
Old Jun 14, 2021 | 02:22 PM
Jooe's Avatar
Jooe
Stage I
Default From inside the trans
Originally Posted by lksmitty
You don't have to remove the primary to remove the shaft...there's a bolt that holds the shifting rod on just like the shift levers. Loosen all three and you can pull out the shifter shaft.
you mean from inside the trans
Old Jun 14, 2021 | 08:47 PM
btsom's Avatar
btsom
The OP talked about the toe and heel levers being loose so that pretty well means the front shaft. The shaft can be easily removed from the primary case by removing the inner shift arm, then the shaft just slides out. If the OP is correct that the splines on the shaft are damaged, he would be wise to also replace the heel and toe levers. If all of those levers are kept tight, they will last the life of the bike. If they get loose, the splines will round off or strip completely. He should absolutely check the tightness of the lever on the transmission to make sure it is solidly tight.
Old Jun 14, 2021 | 11:42 PM
deadhawg's Avatar
deadhawg
Ten year old thread revival!
Old Jun 15, 2021 | 12:20 AM
vizcarmb's Avatar
vizcarmb
Perfect timing. I had the same issue yesterday. Luckily it was on the way home
jeremy2854
Jul 28, 2013 07:21 PM
bobbyjoes
Jun 14, 2013 09:44 PM
skdvr
Apr 17, 2012 11:33 AM
PDDGM
Oct 9, 2008 04:42 PM
zubaugh
Apr 26, 2008 01:25 PM
