Compensator operation
Old Nov 8, 2010 | 08:34 AM
CT-Bagger's Avatar
CT-Bagger
Default Compensator operation
All this talk I see about the compensator.
What exactly is it and what does it do?
Is an upgrade advised?
Old Nov 8, 2010 | 09:11 AM
Bingee's Avatar
Bingee
The compensator is there to cushion the pulsating forces of the engine crankshaft rotating against the the drive train components. Without it, there would be increased vibration and a "jerky" feel, especially at low speed. Not a good thing. Also, the shock of the uncushoned pulses would tend to prematurely wear out components like the primary chain, gears, and bearings.
NickD's Avatar
NickD
Basically it's a "shock absorber" for your drive train. It smooths out the transfer of power between your motor and transmission thereby easing the life of the components on both ends. It also allows your starter (more specifically the jackshaft that engages the ring gear in your primary) a little slack so it doesn't encounter the resistance of the motor right off the bat. This helps the jackshaft engage better. Also, if you're a bit ham handed with the clutch while going through the gears it makes you feel like a better rider than you really are, LOL!
In contrast if you run a dry clutch and a belt drive in your primary (instead of a chain) there is no compensator and in effect your motor and transmission are solidly connected to each other except for the minimal amount of "give" the actual belt may provide. And it's also the reason us guys running open belt drives have to pay a bit more attention to the style of starter jackshafts we use and how we install them.
JIB
Jan 21, 2014 08:57 PM
ApplicationError
Engine Mechanical Topics
Jul 24, 2012 07:08 AM
boot8484
Feb 16, 2012 08:23 AM
waynemags
Custom Models
Jun 14, 2010 04:57 PM
sornamins
EVO
Sep 19, 2009 07:17 PM
