Why do SE255's get such a bad rep ?
Hope this helps..
this cam provides great low-end torque along with
good midrange. A good all-around cam, the Se-254e
is a good match for a Dyna, Softail or light touring bike
- road KingŽ, Street glideŽ or road glideŽ Custom -
when the aggressive rider desires a little more top-end
horsepower. In a 0-60 sprint or 1/4 mile drag race, the
Se-254e-equipped model would pull ahead of an identical
model with a Se-255 cam.
No. It is a bolt-in cam and no other mods need to be made except adjustments to your EFI map. Most will not even need a stronger clutch spring.
Put the 254's and 255's in two otherwise-stock TC96 bikes, and let's assume they both perform equally with stock cams. In a drag race the 254's will likely pull the 255's soon after starting, while the 255's may pull best at the beginning before the engines approach their redline. OTOH, put both bikes in 5th gear and punch them at 2300 RPM. The 255 bike will likely walk the 254's, probably impressively. It's all in where you want the power. All that said, add some compression to the 254's and it's inherent weakness in the low-end will decrease as compression increases, to a point of course. That, needless to say, costs more money.
Thanks iclick, makes sense what you are saying. I did talk with the dealership today and they are looking into providing me some dyno torque/hp comparing the three cams from the HQ tech group. If i get paper copies i'll include them in a follow-up post when and if I get them. the dealership did confirm the 254 are a great low end torque with good midrange but I told them I would like to see the numbers before I commit. Having owned a bike with the 255's I am leaning that way especially with the ability to bolt in and then work the heads later. Still looking at 2200 to install cams, bearings, pipes, air breather and tuner.
