Fullsac dual conversion and CVO slipons
Old Nov 11, 2010 | 09:25 PM
Mike's Avatar
Mike
Originally Posted by Mr. Wizard
Call Steve and ask him. Don't be shy.
www.fullsac.com
That's good advice. Steve knows as much about the CVO slip ons as anybody you're gonna find.
Old Nov 11, 2010 | 10:31 PM
Deuce Bigelow's Avatar
Deuce Bigelow
I have the same setup..
I got the Fullsac headpipe and bought a set of 2010 CVO SG mufflers, I put the Fullsac 2" baffles in them.
not a loud as I thought it would be, but I'm very happy with the sound!
piece of cake installing the Fullsac baffles if you use the dremel with the thin wafer cut off disc.
Old Nov 12, 2010 | 05:43 AM
DrPlastic's Avatar
DrPlastic
Don't forget the HarleyGoodies 24" chrome heat shield!
Old Nov 12, 2010 | 12:38 PM
hucks 08's Avatar
hucks 08
i did my cans with the 2",little loud for my taste,but just when you open it up,grind off the two welds and then get them out ,you will see the packing inside,with the packing inside they were alot louder,more rapping sound,i removed the packing and they sound alot better.i would go with the 1 3/4 if i had to do it again,
Old Nov 12, 2010 | 12:46 PM
sargek's Avatar
sargek
I am leaning towards the 1 3/4ths for that reason. Guessing it's easy enough to pull the wrapping and if I don't like it, put it back, or vice versa.
I am surprised at how well my bike runs even with these muffs unmodified. It seems so wierd because they are so damned quiet, you'd think the bike was being choked, but I have to remember these are off a bike with bigger motor and are designed to flow well.
Old Jun 27, 2012 | 09:05 PM
sargek's Avatar
sargek
Hate to revive an old thread but I wanted to make sure no one else made the same stupid mistake I did. I bought the Fullsac 1.75 CVO Power Cores to put in what I thought were my CVO slipons. Well, turns out 65254-00A slipons look exactly like CVO's but are 3.5" and not 4", which is what the power cores fit into. Not Fullsac's fault and I emailed them to see if I can send the cores back but I spent about an hour getting one baffle out, only to find out the cores are too big. I know, measure twice and cut once...I didn't measure at all
Anyway, wanted to save somone the pain if they have a set of these slipons - they won't work with the power cores. I did ask if Fullsac made any 3.5" power cores so if they do, I am in luck
hypecat
Milwaukee Eight (M8)
15
Jun 9, 2019 11:36 AM
jjlw
Exhaust System Topics
Sep 5, 2016 07:39 PM
jjlw
Dec 14, 2015 07:18 AM
ultraclassic53
Sep 30, 2012 10:19 AM
Dakotazeb
Touring Parts
Aug 22, 2009 10:52 AM
