Se performance air install
Old Nov 16, 2010 | 09:31 PM
MILLER41143's Avatar
MILLER41143
Default Se performance air install
I JUST FINISHED INSTALLING
Screamin' Eagle® Heavy Breather Performance Air Cleaner Kit - Chrome ON MY 2010 SG
I WENT FOR A RIDE THIS EVENING AND THE BIKE FEELS GREAT AND MORE RESPONSIVE.
BUT IT SEAMS LIKE WHEN I ROLL ON THE THROTTLE I CAN HEAR THAT THING SUCKING AIR ALMOST TO A POINT WHERE IM WORRIED I MIGHT HAVE AN AIR LEAK.
HAS ANYONE ELSE EXPERIENCED THIS?
Old Nov 16, 2010 | 09:42 PM
rdc401's Avatar
rdc401
they all do that it doesnt have the backing on it, if you will look on the backside of your breather you will see your air filter.it is open now so it gets more air, more power
Old Nov 16, 2010 | 09:48 PM
CT-Bagger's Avatar
CT-Bagger
Normal.
It's how breathing with your mouth wide open sounds.
Old Nov 16, 2010 | 09:49 PM
jpalm's Avatar
jpalm
Did you take off the fuel tank and remove the black bracket that is attached to the heads? I made the same mistake and had about a 1/16" gap on the top 1/3 of the backing plate. You're sucking in unfiltered air if you didn't do that.
Old Nov 16, 2010 | 10:08 PM
MILLER41143
Originally Posted by jpalm
did you take off the fuel tank and remove the black bracket that is attached to the heads? I made the same mistake and had about a 1/16" gap on the top 1/3 of the backing plate. You're sucking in unfiltered air if you didn't do that.
no i didnt i noticed a small gap but the gaskets provided closed up that gap so i need to pull the tank and remove that bracket?
Old Nov 16, 2010 | 10:17 PM
MILLER41143
im looking at that bracket now isnt the throttlebody hooked to it?
Old Nov 16, 2010 | 10:23 PM
PistonPuller's Avatar
PistonPuller
Do you have the instruction sheet? It shows an exploded view of where that bracket is and that you need to remove it.
Old Nov 16, 2010 | 10:24 PM
MILLER41143
Originally Posted by pistonpuller
do you have the instruction sheet? It shows an exploded view of where that bracket is and that you need to remove it.
mine doesnt have that view
what will the tb hook to now?
Old Nov 16, 2010 | 10:28 PM
PistonPuller
Its got 2 bolts on top side of body.
http://www.harley-davidson.com/en_US...ts/-J04481.pdf
Old Nov 16, 2010 | 10:30 PM
MILLER41143
i see it now its B
my instruction sheet didnt have that
how hard is it to pull this tank
what do i need to do to pull it
i need a svc manual!
