Help Required - Simple(?) Electrical Problem
Old Nov 21, 2010 | 01:01 PM
badjustbad's Avatar
badjustbad
Default Help Required - Simple(?) Electrical Problem
I just made some simple lighting changes to my Ultra LTD. I changed out the signal lights front and rear with SG signals, and I changed out the front fender tip light.
Now when I hit the right signal it flashes normal a couple of times then it speeds up and flashes quickly until I turn it off. The left signal functions properly. The rear signal light connections are solid and I have check the bulbs, front and rear. It is flashing front and rear, so it is not a burned out bulb problem (My first thought.). I haven't taken off the fairing to check the front signal connections.
I suspect there is a ground somewhere in the wiring but F-me, this is the simplest wiring you can do on your bike - the replacements from H-D are very simple plug and play.
Other than checking the connections behind the fairing, does anybody have any thoughts on where I should start looking.
Old Nov 21, 2010 | 01:28 PM
dawg's Avatar
dawg
Have you checked for any codes? Tried replacing the front right bulb irregardless if it looks good?
Old Nov 21, 2010 | 01:36 PM
badjustbad's Avatar
badjustbad
No codes, and I should have added, I did replace the bulb.
I think the fact that it flashes normal a couple of times before it goes goofy is a hint as to the problem. I suspect whatever it is that makes the flasher flash is being generated by some bad wiring. To explain, if it is increased resistance that causes the flasher to flash, then there is some additional resistance being introduced into the circuit. Maybe more voltage draw, voltage drop, heated circuit...
I don't know... I'm not an electrician. <G>
Old Nov 21, 2010 | 02:20 PM
EddieBlaize's Avatar
EddieBlaize
When I replaced the front turn signals with the bullet style, I had a similar problem. Turns out one of the new signals was wired wrong from the factory. I switched the blue and purple wires in the connector and it worked fine.
It took me a while to figure that one out.
Old Nov 21, 2010 | 03:32 PM
FDHOG's Avatar
FDHOG
Usually when one turn signal flashes fast it is a problem with the other bulb. You know when you blow out your right light, the left flashes quickly. I would look towards the other signal light for the problem.
Old Nov 21, 2010 | 04:31 PM
piasspj's Avatar
piasspj
I'd remove the bulbs, coat them with dielectric grease and reinstall. Sounds like something isn't quite right.
Old Nov 21, 2010 | 09:30 PM
hot95hog's Avatar
hot95hog
Incorrect. When you have a blown bulb the side that has a bad bulb will flash correctly three or so times and then speed up real fast. When you have a bad ground you will get alternating problems and then it can be left or right; front or rear.
The fastest and easiest way is to swap the front turn signal bulbs left to right then check, if it is still the same then swap the rear. When the left starts flashing fast then you know which bulb is the problem.
My 09 RG had a bad front turn signal bulb on the left and I had the same problem you did.; Changed the affecting bulb and problem fixed. I still use STD bulbs NOT LED. If you went from one type to the other then you may need a equalizer, not sure what the LTD uses from the factory.
By the way both my front and rear flashed like you would think they do. What happens is when the bulb is bad it chases for a ground and then finds it thru the marker light. (other filament), thus both flash and you think all is good with the bulbs.
Old Nov 22, 2010 | 11:59 AM
badjustbad's Avatar
badjustbad
Thanks to everyone for all the tips and suggestions.
I've pretty much ruled out the bulbs (They've been swapped out one at a time and I did grease the sockets when I replaced them.).
As EddieBlaize suggested, they may be wired wrong from the factory and I need to rule it out, too. I think I'll get the test light out and test the wiring in the billet signals or I could simply plug in the old lights to see if the problem is now also with the old lights.
The LED lights are on the way from Badlands so I need to get this fixed up before they get here. Things don't wait around in boxes very long after they arrive in the mail. <G>
Old Nov 26, 2010 | 02:00 PM
EddieBlaize
Did you get this fixed? What was the problem?
Old Nov 26, 2010 | 02:03 PM
FDHOG's Avatar
FDHOG
I stand corrected. That's what happens when you're retired and drink in the afternoon.
