Leaking Air!
Old Nov 22, 2010 | 12:01 PM
Rageous's Avatar
Rageous
Arrow Leaking Air!
The 2011 Ultra Limited is not holding air in the rear shocks. I bought the HD hand pump to make sure I get the right PSI. I have been running 50PSI. But every time I check the AP it is low, and last weekend took the wife to Breckenridge (about 200 mile round trip) and on the way back I noticed that we were hitting hard again.
Is it normal for the rear suspension to leak air so badly, any advice?
Thanks
Mike
Old Nov 22, 2010 | 12:02 PM
slothy's Avatar
slothy
put some air in them, then take some soapy water and spray it around the fittings/hoses and see if its just a leaking fitting (will get bubbles).
Old Nov 22, 2010 | 12:05 PM
DrPlastic's Avatar
DrPlastic
Just push in on all the hose connections. If that doesn't do it then push in on the red collars and remove the air lines. Then reinstall the lines by firmly but gently pushing in the line until it seats. Hope that helps. Also do you have an oil leakage on one of your shocks? If it is leaking air then it is in most probability leaking oil also.
If not take it back to the dealer for this obvious warranty job!
Old Nov 22, 2010 | 12:12 PM
Giddy_up's Avatar
Giddy_up
I don't know about the newer models, but my 03 Ultra will only accept 35 psi max. in the rear shocks. Be careful to not overfill them or you may damage a seal and they'll leak. A quick check is the soapy water suggested by slothy.
Old Nov 22, 2010 | 12:39 PM
Saint666's Avatar
Saint666
Nope its not normal,,Take the bike to your dealer and make them solve the problem,,Its a brand new bike,,that shouldnt happen.It will leak some air but not that fast.
Old Nov 22, 2010 | 12:45 PM
Wibbo's Avatar
Wibbo
50 psi sounds a bit much
Old Nov 22, 2010 | 12:46 PM
Spurrs's Avatar
Spurrs
Warranty for sure - they shouldn't leak.
Old Nov 22, 2010 | 12:51 PM
slothy's Avatar
slothy
ya check owners manual, it gives you recommend psi, i remember their being 2 tables for them
sifularson's Avatar
sifularson
FYI - HD raised the maximum a few years ago to 50 PSI. In the manual, it states to never exceed 50. That PSI is recommended for a fully loaded bike with a 300lb rider/passenger weight.
Old Nov 22, 2010 | 01:02 PM
Wibbo's Avatar
Wibbo
ah ok .. i stand corrected
