Anyone ever use the Yaffe supersize kit?
Old Nov 27, 2010 | 12:42 AM
slothy's Avatar
slothy
to remove the pins from the bar connectors, just use needle pliers to oull out the center and use a small screwdriver to pull tabs up and the pins slide out from back. already did one side, just waiting on se throttle to come in, so i can finish throttle side.
Old Nov 27, 2010 | 06:48 AM
FLHXTC's Avatar
FLHXTC
I went with the PYO 12's also. I got the extended TBW, but didn't need it. Did not need to extend wires either. I used the paper clip trick to remove connectors and worked great. Wiring is a PITA though, but they look great in the end! Almost went with the 10's, glad I didn't. I'm 6'1" and there perfect. I got mine from Phat Performance Parts, and they were in stock. Looks like they have 12's in stock now.
Old Dec 23, 2010 | 11:40 PM
batstreetglide's Avatar
batstreetglide
6th Gear
you guys are saying that with the 12's you dont need to extended the wires only the cluth and the brake lines?
Old Dec 24, 2010 | 07:29 AM
rg_dave's Avatar
rg_dave
Correct. Just reposition the plugs under the radio.
Old Dec 27, 2010 | 10:31 PM
batstreetglide
6th Gear
Any Idea what size cables I need.Would be a great help
Old Dec 28, 2010 | 07:17 AM
Geekzter's Avatar
Geekzter
For 12 inch Monkey Bars I went with +8 Clutch and +6 Brake. Contact Shawn at DR. V-Twin he can help you if you have not purchased your cables yet.
James (Miami)
Old Dec 28, 2010 | 02:55 PM
rg_dave's Avatar
rg_dave
James (Miami)
Same here. Went with the Magnum Sterling Chromite. Dr.Vtwin was great to deal with.
Old Dec 28, 2010 | 10:15 PM
batstreetglide
6th Gear
this may be a stupid question but how did you get the wires to fish thru the bars , do you have to strip the controls complety or did you cut and re-solder the wires.
Old Dec 28, 2010 | 10:25 PM
slothy's Avatar
slothy
you pull the pins outa the connector
Old Jan 2, 2011 | 03:39 PM
batstreetglide
6th Gear
How much longer for the throttle and idle cabels.?
