Drill a hole in baffle for Dyno??
Old Nov 29, 2010 | 12:07 AM
po1192's Avatar
po1192
Default Drill a hole in baffle for Dyno??
Dyno dude wanted to drill a hole in my baffle for a Dyno...this routine??I have v&H true duals (oval)
Old Nov 29, 2010 | 12:12 AM
Mike's Avatar
Mike
Are you talking about a hole so he could insert the probe? If it was the only way he could insert the probe, then yes, it's a normal thing. It's a small hole, won't change your performance a bit.
Old Nov 29, 2010 | 05:46 AM
NELS's Avatar
NELS
I have the same problem with V&H headers using stock mufflers. The tech is ordering adaptors from V&H to use the 02 holes to insert the probe. I'm still waiting over two months. I've been in contact with him and can't see why it is taking so long. Think I'll poke a hole in my baffle but don't want to make it much louder. Anyone else done this?
Old Nov 29, 2010 | 06:14 AM
harleytuner's Avatar
harleytuner
It's pretty common. I've done it quite a bit. Especially on '06 and earlier bikes that didn't have o2 sensors. Bikes with o2 sensors I just take the o2 sensor out and put the o2 sensor from the sniffer in. I made my own adapter, just drilled a 1/4" hole in a o2 sensor plug and it works just fine, I only use it when I don't have room to get the sensor from the sniffer in the head pipe. If you let him drill it, you won't notice a diffence in the sound or performance.
Old Nov 29, 2010 | 07:24 AM
NELS's Avatar
NELS
Thanks for the info Harleytuner. I'll have to do that.
Old Nov 29, 2010 | 10:51 AM
po1192's Avatar
po1192
Cool, thanks for the input. Yes, its for the probe. the Dyno guy says there isnt room to slide the probe by the baffle, ,,SO.. i let him drill a small hole, he says you'll never know.
strat10
Exhaust System Topics
Oct 23, 2016 10:18 PM
tsigwing
11
Dec 29, 2014 05:09 PM
nerider2
Feb 16, 2014 09:40 AM
Tripleshot
Dec 10, 2011 05:12 PM
00ultra
Feb 9, 2006 02:06 PM
