Code Master Service Code Reader
Old Dec 4, 2010 | 10:07 AM
Xzotik's Avatar
Xzotik
Default Code Master Service Code Reader
Does this tool from HD do any more than can be done manually on the odometer?
Be prepared when you visit your dealer for service. Diagnostic code scanner easily retrieves trouble codes from your vehicle's computer to diagnose problems. The pocket-sized diagnostic code reader simply plugs into your bike's vehicle port, and automatically connects to the onboard computer. It reads the Diagnostic Trouble Codes (DTC) and displays the DTC description on a bright LCD screen. The Code Reader Master allows you to clear codes with the touch of a button, and also lets you to double check the current calibration ID for your motorcycle. The Code Reader is powered by your bike when connected. Kit includes palm-sized reader, J1850 connection cord, and instructions. Available starting March 2010.
32312-10
For use on '02-'11 VRSC™, '07-'11 XL and XR, '02-'11 Dyna®, '01-'10 Softail®, and '02-'11 Touring models equipped with J1850 protocol On-Board Diagnostics information plug.
MSRP US $149.95
Link
Old Dec 4, 2010 | 10:15 AM
BadPiggy's Avatar
BadPiggy
I bought one about 6 months ago.
Damn thing has yet to make it out of the packaging.
Your odometer can give you the codes as easily as this thing can.
If you INSIST on buying one...PM me, I'll hook a brutha' up!
Otherwise, save your money.
Old Dec 4, 2010 | 10:51 AM
Guntoter's Avatar
Guntoter
Where is the diagnostic port located at on the bike?
Old Dec 4, 2010 | 11:00 AM
BadPiggy's Avatar
BadPiggy
Left side cover.
EDIT: On a '08 that's where it's located.
Old Dec 4, 2010 | 02:00 PM
dawg's Avatar
dawg
I believe about the only other thing it would do is indicate what current download is in the ECM. Not worth it, IMO
Old Dec 4, 2010 | 03:41 PM
Mike's Avatar
Mike
There are times I've wished my Snap on red brick scanner would work with my bike, but really the built in code reader does almost as much anyway.
Old Feb 10, 2011 | 10:26 AM
Happy_Madison_'s Avatar
Happy_Madison_
1st Gear
Default Code Reader,Missing Key Fob
would this work to tell me a security code for reprograming new key fobs the dealer is telling me that if the security sys is locked I need to buy a new TSSM 285$ seems like it would be just as easy for me to do it with this.
Old Mar 16, 2011 | 10:01 AM
sajobob's Avatar
sajobob
6th Gear
Default Scanner
I tried this one and as someone else said you can get the same info from the odometer. I finally bit the bullet and bought one of the MS5650 scanners. This tool is great, gets me all the info I need. Warning it is a little pricey, best price I got was from a company called Griffin Tools & Supply out of Illinois.
Old Mar 16, 2011 | 10:12 AM
Jim Dawson's Avatar
Jim Dawson
Originally Posted by sajobob
...Warning it is a little pricey, best price I got was from a company called Griffin Tools & Supply out of Illinois.
A little pricey? $2850
Old Apr 21, 2011 | 05:20 PM
sajobob's Avatar
sajobob
6th Gear
Talking Yes a little pricey!
It is an expensive piece of equipment but I work on all types of bikes and scooters and I have not found one it will not work with. I orginally bought just the HD and BMW cables but then quickly added the Honda, Yamaha, and Kawasaki cables. One of the better investments I've made.
